switchport setup for lwapp access point running several ssid's
Answered Question
Sep 17th, 2010
Hi all
when setting up an lwapp acces point, do I need to trunk all the vlans on the port to the ap? or do I only need to enable the management vlan to the acces point ? ie 1 vlan and normal access port ?
cheers
Carl
Correct Answer by Surendra BG about 6 years 5 months ago
If its a LWAPP AP, then the switchport should be a ACCESS PORT.. this is just to get the IP address to the AP, then the AP wil try to join the WLC.. once the AP joins, the SSID and rest flow through the LWAPP tunnel..
Surendra
Overall Rating: 5 (2 ratings)
Correct Answer
Surendra BG Fri, 09/17/2010 - 05:05
Surendra
