Corrupt IOS in 3750, not enough space to load image..Help
Sep 17th, 2010
Corrupt IOS on 3750.  How do I view and delete files to make space in Recovery mode (System: ) to Xmodem an IOS?  I see the directory that I need to delete files, but can't CD to it so I can delete files. Failed twice during the xmodem copy, not enough space to load new IOS.
andrewswanson Fri, 09/17/2010 - 07:52
delete /recursive /force flash: will delete the folder and its contents
Nagaraja Thanthry Fri, 09/17/2010 - 07:53
When you do a recovery from the switch mode (when you load the image via xmodem), it will automatically format the flash and load the new image onto the flash.
jamesross Fri, 09/17/2010 - 07:57
It aborts the modem copy with a not enough space available.  So I need to delete some files to make room, and that's where I'm lost.  I don't know the command to change directory so I can start deleting.  I didn't try the format command...humm.
Nagaraja Thanthry Fri, 09/17/2010 - 08:10
Please try the following:
switch: dir flash:
Directory of flash:/
    2  -rwx  12272570            c3750-ipservicesk9-mz.122-52.SE.bin
    3  -rwx  616                      vlan.dat
  397  drwx  64                       crashinfo_ext
   401  drwx  128                    crashinfo
    7  -rwx  3096                     multiple-fs
  410  -rwx  109                      info
    9  -rwx  1951                     config.text
19919360 bytes available (12594688 bytes used)
switch: delete flash:/c3750-ipservicesk9-mz.122-52.SE/c3560-ipservicesk9-mz.122-52.SE.bin
That should work.
