Span VLAN between 2 sites
Answered Question
Sep 17th, 2010
I need to span a vlan between 2 sites connected via ETHERNET. What is best layer 2 solution for this implementation.
I have users in site 1 who needs to talk to users in sites 2 in same vlan.
Correct Answer by Federico Coto F... about 6 years 5 months ago
To span a layer 2 domain over a layer 3 domain can use QinQ or L2TPv3 (i'm sure there are other ways but don't recall now).
Federico.
Overall Rating: 5 (1 ratings)
Federico Coto F... Fri, 09/17/2010 - 10:28
If you want users on siteA to talk to users on siteB, you don't need to span the VLAN across.
I mean, you can have layer 3 IP connectivity just by using regular routing.
If on the other hand, you need to span the VLAN between a layer 3 domain, there are some mechanisms to do it
i.e.
QinQ, L2TPv3 and some others.
I just see sometimes people confused that they need to span a VLAN across a layer 3 domain, when they actually just need communication.
Correct me if I'm wrong and please describe what you need.
Federico.
smailbouabdallah Fri, 09/17/2010 - 11:32
Thanks for quick reply. The business is looking for layer 2 solution. Can you suggest any layer 2 implementation?
Correct Answer
Federico Coto F... Fri, 09/17/2010 - 11:36
Federico.
