Remote Button Programing
Answered Question
Sep 17th, 2010
I'm able to program the remote buttons with no problem but, i have over 60 DMPs deployed and would like to be able to program them all at once.  Is there a way in the DMM to write an advanced task app that will program the button remote?
Al
Correct Answer by Tomas De Leon about 6 years 7 months ago
Try this string to set the YELLOW button and then you can use this
as a template:
irasrv.key_YELLOW=ira%20add%201%20sh%201%20YELLOW%20bg%20wget%20-q%20%22localhost%3a7777%2Fset_param%3Finit.BROWSER_CMD%3Dhttp://www.yahoo.com%22
Notice: in your string you are NOT escaping the RESERVED codes.  Per URL addressing spec RESERVED
characters need to be escaped.
I hope this clarifies this.
Also, test your string in the browser first and then you only add the request after set_param?
Cheers!
T.
Alan,
here is a tech tip that I wrote on programming the buttons on the remote via
a HTTP mib.  Just create an Advanced Task under the System task
for each colored button.  Test & verify it works on a single DMP first and
then send task for each colored button to all of the DMPs.  Once this is
completed make sure you SAVE the configuration.
If this answers your question, Please take time to mark this
discussion answered & rate the response.
Thank You!
T.
You can use DMP MIBs to reconfigure the DMP Remote Buttons.
VARIABLES
  admin           = DMP Web Account Username
  default         = DMP Web Account Password
  a.b.c.d         = IP Address of DMP
  dmm.company.com = FQDN of the Digital Media Manager(DMM) Appliance
MIBS
** Use the Following MIB to see the CURRENT Remote Mappings
https://admin:[email protected]:7777/get_param?p=*.*&init.pop_enable=false
** Configure Buttons
RED
https://admin:[email protected]:[email protected][email protected]Dwww.cisco.com%22
GREEN
https://admin:[email protected]:[email protected][email protected]MD%3Dhttp://www.google.com%22
YELLOW
https://admin:[email protected]:[email protected][email protected]_CMD%3Dhttp://www.yahoo.com%22
BLUE
https://admin:[email protected]:[email protected][email protected]%3Dhttp://www.apple.com%22
ASSIGN A BUTTON TO CAST
https://admin:[email protected]:[email protected][email protected]Dhttp://dmm.company.com:8080/etv-flash-webapp/app/etv_24_.htm%22
** Use the Following MIB to see the NEW CONFIGURED Remote Mappings
** Save NEW CONFIGURED Remote Mappings on DMP
   -> Use the ADVANCED TASK to SAVE the DMP Settings.
   -> or Directly on the DMP using the DMP-DM Web Admin
   -> or HTTP MIB
         ie.
         https://admin:[email protected]:7777/set_param?mib.save=1
         https://admin:[email protected]:7777/set_param?mib.save=1&mng.reboot=1
Overall Rating: 5 (2 ratings)
Correct Answer
Tomas De Leon Fri, 09/17/2010 - 10:29
  • Cisco Employee,
Alan,
Thank You!
T.
VARIABLES
MIBS
RED
GREEN
YELLOW
BLUE
   -> or HTTP MIB
         ie.
Correct Answer
Tomas De Leon Fri, 09/17/2010 - 12:58
  • Cisco Employee,
as a template:
Cheers!
T.
sharpgate Sat, 09/25/2010 - 07:00
Hi Tomas,
May I know how to send an HTTP MIB request to a certain DMP to simulate a "remote" key click if I don't now have a remote handy. Say I want to test the Yellow button after it is programmed. I heared there was a remote simulator application out there but don't know how to get it?
