Which networks are sent to the EZvpn Headend ?
Sep 17th, 2010
Does anyone know which networks are selected by the harware client to be sent to the vpn headend device?  Are the networks select from the static routes? or from the routes on the routing table (received via a routing protocol?)? is there a way to influence this decision?
thanks!
Diogo
Lei Tian Fri, 09/17/2010 - 08:19
  • Cisco Employee,
Hi Diogo,
That decision is made by the ACL pushing down from EZVPN server.
HTH,
Lei Tian
Lei Tian Fri, 09/17/2010 - 12:02
  • Cisco Employee,
Hi Diogo,
We are talking about the same thing. Search 'acl SPLIT_T' in the document you were looking for. This is the ACL used to control what traffic will be sent to headend.
HTH,
Lei Tian
diogo Fri, 09/17/2010 - 12:12
OK,  you're right.  But what if I don't want to use split tunnel? Or do I must?
Diogo
Lei Tian Fri, 09/17/2010 - 12:30
  • Cisco Employee,
Hi Diogo,
That's how EZVPN works. Everything is controlled from server side. If you want more control from the client, run site to site vpn or gre + ipsec.
HTH,
Lei Tian
