Difference between WS-X6066-SLB-S and WS-X6066-SLB-APC
Sep 17th, 2010
Dear all
I have two 6509 chassis with Sup720 and MSFC3.
Additionally I have one module
"CSM with SSL"   WS-X6066-SLB-S-K9  Hw. 1.2, Sw. 2.2(1)
and one module
"SLB Application Processor Complex"  WS-X6066-SLB-APC Hw. 1.6, Sw. 4.3(1)
I am searching the Cisco site up and down and cannot really tell the difference between these modules.
So what's the difference?
And would it be possible to run the same software on both CSM modules?
As far as I see 4.3(5) is the latest release for the WS-X6066-SLB-APC, but what about the WS-X6066-SLB-S-K9?
Thanks for any hints,
Grischa
Jon Marshall Sat, 09/18/2010 - 11:06
grischast wrote:
Dear all
and one module
Grischa
Grischa
They are both load-balancing modules but the WS-X6066-SLB-S-K9 is capable of load-balancing SSL as it has a inbuilt SSL daughter card which the WS-X6066-SLB-APC does not.
No the same software is not run on both modules, the latest version of the CSM-SSL module (WS-X6066-SLB-S-K9) is 2.2(5).
Jon
