09-17-2010 10:36 AM - edited 03-04-2019 09:48 AM
We use Nagios to monitor our 4 core routers. 2 of which are our main BGP routers. We use Nagios to monitor these devices. Periodically we get an alarm in nagios stating its not-responding and within a few minutes another alert clearing the previous one stating all is ok. Everytime I log into the device I don't see anything going on. Its up and appears to be operational. The only thing I find is that the CPU seems to take a spike around the same time from the BGP Router process. We are recieving a total of 623763 prefixes from our bgp neighbors. Has anyone seen anything like this before? Could this be a problem with nagios or the BGP process? IT doesn't appear to be a memory issue as we appear to haver plenty of free memory. Any help would be great. Thanks!
BGP table version is 33649554, main routing table version 33649554
328279 network entries using 38408643 bytes of memory
623763 path entries using 32435676 bytes of memory
1136755/71241 BGP path/bestpath attribute entries using 181880800 bytes of memory
677951 BGP AS-PATH entries using 32045892 bytes of memory
4091 BGP community entries using 186952 bytes of memory
1 BGP extended community entries using 24 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP using 284957987 total bytes of memory
12064 received paths for inbound soft reconfiguration
BGP activity 924004/593348 prefixes, 5688171/5062032 paths, scan interval 60 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
1.x.x.x 4 26482 6451091 14376090 33649554 0 0 9w6d 289913
2.x.x.x 4 26482 99567 99456 33649554 0 0 9w6d 4
3.x.x.x 4 26482 99569 99456 33649581 0 0 9w6d 8
4.x.x.x 4 26482 99579 99467 33649581 0 0 5w1d 15
5.x.x.x 4 26482 100265 99446 33649581 0 0 9w6d 36
6.x.x.x 4 29779 300772 293277 33649542 0 0 2w3d 1
7.x.x.x 4 64512 100266 99457 33649542 0 0 6w0d 1
8.x.x.x 4 64513 4572 4127 33649542 0 0 1d19h 0
9.x.x.x 4 10913 53153649 99456 33649542 0 0 9w6d 321716
sh memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 462F7650 902826416 630503748 272322668 270728408 266354900
I/O 8000000 67108864 21605604 45503260 45357096 45501532
cisco WS-C6504-E (R7000) processor (revision 2.0) with 983008K/65536K bytes of memory.
Processor board ID FOX103304ZT
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 Enhanced FlexWAN controller (2 Serial).
1 Virtual Ethernet interface
50 Gigabit Ethernet interfaces
2 Serial interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
09-17-2010 12:08 PM
Answered in Lan Routing & Switching.
To the OP, please don't post into multiple forums as it just confuses the issue.
Jon
