Cisco Unity Connection Architectural Overview
Answered Question
Sep 17th, 2010
Does anyone have the Cisco Unity Connection Architectural Diagram.The architectural diagram for Cisco unity is available and we have Cisco Doc written by Jeff Lindborg for the same,but I am not able to find the Cisco Unity Connection Architectural Diagram.
Can anyone tell me  where I can  get this ??
Thanks & Regards,
Hasan Jafri
Correct Answer by Scott Hills about 6 years 4 months ago
Back with Unity Connection 2.x the following was made: Connection 2.0 architecture which can be found at:
http://ciscounitytools.com/Training/Connection/CUC2_01.html
At this location you will find Video and Power Points regarding this. I have not found anything further for future release. Generally only when something changes or new feature is added do things get updated here for future versions.
Take a look and see if this contains any information you might be looking.
Scott
Correct Answer
Scott Hills Fri, 09/17/2010 - 18:58
Scott
Mohammad Hasan ... Mon, 09/20/2010 - 08:24
Thank you for your reply.
I was looking for the architectural change that might be there in Unity Connection 7.x.
I believe you are right may be there is no major change in the architecture of Unity Connection 7.x
Thank you for your help!!
Thanks ,
Jafri
