1252 AP wont stay associated 5508 wlc
Sep 17th, 2010
I have a newly configured 5508 and a test 1252 ap. The ap connects to the controller and then drops off repeatedly. I have pasted the errors that I am seeing on the ap below.
*Sep 17 17:22:01.807: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Sep 17 17:22:02.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: 10.200.25.34 peer_port: 5246
*Sep 17 17:22:02.000: %CAPWAP-5-CHANGED: CAPWAP changed state to
*Sep 17 17:22:02.719: %CAPWAP-5-DTLSREQSUCC: DTLS connection created sucessfully peer_ip: 10.200.25.34 peer_port: 5246
*Sep 17 17:22:02.719: %CAPWAP-5-SENDJOIN: sending Join Request to 10.200.25.34
*Sep 17 17:22:02.719: %CAPWAP-5-CHANGED: CAPWAP changed state to JOIN
*Sep 17 17:22:02.791: %CAPWAP-5-CHANGED: CAPWAP changed state to CFG
*Sep 17 17:22:13.463: %CDP_PD-2-POWER_LOW: All radios disabled - NEGOTIATED WS-C3750-48P (0027.0c8b.3d9d)
., 1)17 17:22:20.791: %CAPWAP-3-ERRORLOG: Retransmission count for packet exceeded max(UNKNOWN_MESSAGE_TYPE (5)
*Sep 17 17:22:20.791: %CAPWAP-3-ERRORLOG: GOING BACK TO DISCOVER MODE
*Sep 17 17:22:20.791: %DTLS-5-SEND_ALERT: Send WARNING : Close notify Alert to 10.200.25.34 5246
*Sep 17 17:22:20.827: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Sep 17 17:22:20.827: bsnInitRcbSlot: slot 0 has NO radio
*Sep 17 17:22:20.827: bsnInitRcbSlot: slot 1 has NO radio
D
janesh_abey Fri, 09/17/2010 - 16:06
Based on your log, AP does not progress  after the Join request is sent to the WLC..
Can you get us a debug output from the controller if its not in production ?This will tell us whether the Join request was received or not and also what is happening at the path MTU discovery stage.Also what is the version of code on the WLC ? remember reading about a bug that prevents APs with  MACs starting with 00 from joining the controllers  but that was for 6.0.188.0.Last not least ensure that  NTP is working as well as that could be a culprit as well.
cheers,
Janesh
deesimba1 Sat, 09/18/2010 - 00:38
Thanks for the reply,
I have checked the time on the wlc and it is correct, it didnt have an ntp source but I have added one. The sw version is 6.0.199.0. I turned debugging on for the wlc and get the below output over and over again. There is no duplicate AP as this is the only one connected.
Many Thanks,
D
*Sep 18 09:37:00.662: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1077 AP with same name APd0d0.fded.30a2 exist. Using default name APd0d0.fded.30a2 for this AP.
*Sep 18 09:36:31.840: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1077 AP with same name APd0d0.fded.30a2 exist. Using default name APd0d0.fded.30a2 for this AP.
*Sep 18 09:35:42.026: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1077 AP with same name APd0d0.fded.30a2 exist. Using default name APd0d0.fded.30a2 for this AP.
*Sep 18 09:35:37.417: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:35.417: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:31.327: %LWAPP-6-CAPWAP_SUPP_VER: spam_lrad.c:1723 Discarding discovery request in LWAPP from AP d0:d0:fd:ed:30:a2 supporting CAPWAP
*Sep 18 09:35:31.283: %DTLS-5-PEER_DISCONNECT: openssl_dtls.c:659 DTLS peer 10.112.3.10 has closed connection.
*Sep 18 09:35:25.415: %SNTP-7-NO_ACCEPTABLE_PKTS: sntp_main.c:1004 No acceptable packets received.
*Sep 18 09:35:25.415: %SNTP-7-TOO_MANY_BAD_PKTS: sntp_main.c:960 Too many bad or lost packets.
*Sep 18 09:35:25.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:23.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:21.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:19.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:17.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select system call failed.Error Code: 0
*Sep 18 09:35:15.415: %SNTP-7-SELECT_FAILED: socket.c:369 The select
Leo Laohoo Sun, 09/19/2010 - 01:58
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
What the ...???
How many APs can your WLC and how many APs are currently joined?
frr8trane Mon, 10/18/2010 - 12:58
Have you found a solution to this problem? I am also experiencing a problem with an AP joining a controller. I have a wlc 2012 with 1131ag access points. Currently have 6 AP's on the controller and the 7th is throwing the following error and not fully joining the controller.
*Oct 18 19:54:39.942: %CAPWAP-3-DUP_AP_NAME: capwap_ac_decode.c:1077 AP with same name AP0015.faa3.e2a6 exist. Using default name AP0015.faa3.e2a6 for this AP.
Leo Laohoo Mon, 10/18/2010 - 14:21
  • Hall of Fame,
    2017 LAN, Wireless
How many APs are currently joined to the 2012 WLC?
