Connecting a wireless router to a wired router
Sep 17th, 2010
I have a Linksys/Cisco BEFSR81 cable/DSL router with 8 port switch.  I need to add wireless capability to the system so I can connect up to 11 computers in my home.  Is it possible to attach a Cisco WRT400N dual band wireless N router to one of my ports on the BEFSR81?
If this is possible, would there be anything else I need to do to make this happen.  This will allow all of our computers and laptops to share the internet connection.
Justin Brenton Fri, 09/17/2010 - 21:32
  • Silver, 250 points or more
Hi there,
You should be fine.
I would set a static ip address on the wireless router with a default gateway of the DSL modem, you could also hard code the duplex and speed on both sides, because your using a N router which is probably 1000MB and the Cisco DSL modem is most likely 100MB.
HTH, please rate below if so.
Justin
