How to disable username and password on Catalyst 4503
Answered Question
Sep 17th, 2010
Hi all :
I have faced this username and password problem about couples of weeks but still no solution. Any one can help?
The steps below have been done but yet no positive result :
1. Press CTRL-C just within 5 sec after the switch boot up and enter to the ROMMON mode.
2. Have done confreg 0x2141 / 0x2142 and reset or restart the switch, but yet the swicth still prompt out the username and password.
3. Have tried after loading the IOS and press CTRL-C before the switch loading other files to cards or switch itself but the switch does not quit to ROMMON mode. It can go to ROMMON mode when press CTRL-C within 5 sec right after the switch is boot up.
Any way to resolve this problem? Please help. Thanks a lot!
regards..
Correct Answer by Nagaraja Thanthry about 6 years 5 months ago
You need to perform ROMMON recovery. Please try the following procedure:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml#image
Hope this helps.
NT
If you notice, the switch did not take the command you entered. Your ROMMON version does not allow you to set the Config Register value the way you have tried.
rommon 1 >confreg 0x2142
usage: confreg
rommon 2 >reset
******** The system will autoboot now ********
config-register = 0x102
Autobooting using BOOT variable specified file.....
Current BOOT file is --- bootflash:cat4500-ipbase-mz.122-37.SG.bin
Please try the following:
rommon 1 > confreg
Configuration Summary :
=> load ROM after netboot fails
=> console baud: 9600
=> autoboot from: commands specified in 'BOOT' environment variable
do you wish to change the configuration? y/n  [n]:  y
enable  "diagnostic mode"? y/n  [n]:  n
enable  "use net in IP bcast address"? y/n  [n]:  n
disable "load ROM after netboot fails"? y/n  [n]:  n
enable  "use all zero broadcast"? y/n  [n]:  n
enable  "break/abort has effect"? y/n  [n]:  n
enable  "ignore system config info"? y/n  [n]:  y
change console baud rate? y/n  [n]:  n
change the boot characteristics? y/n  [n]:  n
Once you are done with the above, reset the switch. You will be able to get into the switch and be able to configure it.
Hope this helps.
NT
Overall Rating: 5 (3 ratings)
Tang-Suan Tan Sat, 09/18/2010 - 02:27
Hi Nagaraja :
Glad to hear from you!
Yes, I follow the same procedure as your link. Attach please see the console text file for your reference. Please advise and let me know anything you need for solving this problem, thanks!
regards..
Correct Answer
Nagaraja Thanthry Sat, 09/18/2010 - 08:00
usage: confreg
rommon 2 >reset
rommon 1 > confreg
Hope this helps.
NT
Tang-Suan Tan Sat, 09/18/2010 - 10:34
Hi Nagaraja :
Thanks for your solution on my this (old) question!
I have another poblem. That is with the same 4503 switch, my IOS were deleted ( because I want to upgrade a new IOS ) and now I only can boot to ROMMON. How to get a IOS ( better an updated IOS ) back to switch in ROMMON mode? I have backed the old IOS before I deleted them.
I have also posted this new problem in the discussion forum, hope you can help me on this too. Thanks!
Tang-Suan Tan Sat, 09/18/2010 - 11:35
Hi Nagaraja :
I got the answer from another helper over this new question. The answer link is the same as you.
From the link, I got resolve the problem. Thanks for your reply!
Best regards..
Tang-Suan Tan Sat, 09/18/2010 - 08:56
Hi Nagaraja :
Thanks a lot for your help! The username and password have been disable!
Many thanks and best regards!
