9971 Key
Answered Question
Sep 18th, 2010
I have Call Manager Version 7.1.3aSU1, i need to configure 6 lines in 9971, when i check in Reorder Phone Button Configuration i find 3 lines just can be added.
thanks
A.Nasser
Correct Answer by Aaron Harrison about 6 years 9 months ago
You'll need to configure a Phone Button Template - this is under 'Device/Device Settings/Phone Button Template'. Find the existing template for a 9971, copy it, and change the lines 4-6 to be 'line' intead of speed dial or whatever they are by default.
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Sat, 09/18/2010 - 03:48
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
