Port Security on a HWIC-D-9ESW
Answered Question
Sep 18th, 2010
I have a HWIC-D-9ESW installed into a 2821 and it won't take any port security commands.  I'm running advanced IP services (12.4(15)t12) on the router.  How can I configure it, or is it not supported?  Thanks in advance for the help.
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
What kind of security features you are trying to enable under the HWIC interfaces?
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t8/feature/guide/esw_cfg.html#wp1043334
Here is the configuration guide for the HWIC cards.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
