Warning message
Fast Dial and Personal Address Book for CM 7
Answered Question
Sep 18th, 2010
Hi there,
can someone please tell me which guide covers configuring and using Fast Dial and Personal Address Book for CM 7.
thx
Correct Answer by Aaron Harrison about 6 years 11 months ago
As long as you have a user associated to the phone (either directly on the end user page, or to an EM profile that is logged into the phone) you should simply be able to go to the Directories menu on the phone, and see the Personal directories there. You don't need to specifically configure them as in previous versions.
Or do you have a more specific need?
Aaron
Please rate helpful posts..
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Sun, 09/19/2010 - 01:50
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
