09-19-2010 01:32 AM
09-19-2010 09:15 AM
Post the ani.log and ANIServer.log.
09-19-2010 10:42 AM
Thanks joseph,
I will upload tomorrow early mornng.
09-20-2010 03:50 AM
Hi Joseph,
Please find the attached ANIServer.log file.
I tried to get ani.log file, but it says "you can open file, as it is being used by another application"
when i stop anidatabase service, i could not see anilog file in its location, but on starting anidatabase service i can see ani.log file (4kb).
Thanks in advance...
09-20-2010 09:26 PM
This error points to a locale problem. LMS is only supported on US English versions of Windows installed with a US English locale. Confirm your server is setup accordingly. It looks like the server might be setup to an Arabic locale.
09-21-2010 03:14 AM
Yes, it is installed in Arabic locale.
I will change regional settings of windows server and will update.
Thanks for your support.
09-22-2010 03:34 AM
Hi Joseph,
I changed the Server Locale from Arabic to US English, but still the same error. I checked the ANIServer.log and found same java.lang.error.
Still the date format of LMS3.0 is arabic. I am using Java version 1.5.0_11-603.Is there any option to change Locale in LMS itself?
Can you please tell me the difference between Licensed and Purchased under "PRODUCT INSTALLED" box?
Thanks in advance.
10-07-2010 06:18 AM
Hello Joseph,
can you please advice what should i do next? If i update to 3.0.1 (maintenance upgrade) will it help ?
Thanks & Regards
Ahmed.
