NM-2CE1T1_PRI showing disabled
We tried to install one E1 card in Cisco 3745 router and we are getting following error.
Slot 3:
        NM-2CE1T1_PRI Port adapter, 2 ports
        Port adapter is disabled deactivated
We installed the same in Cisco 2821 router and getting following error.
Slot 1:
Both the IOS are supports these card and we also confirgured Card type e1 0 3 (card is in slot 3 in 3745)
we have also attached logs (show version / show diag) for both the router.
regards,
Rakesh Prasad
vragotha Sun, 09/19/2010 - 11:06
  • Silver, 250 points or more
Can you swap the NM-2CE1T1_PRI cards in Slot 1 and Slot 3 on the 3745 and see which of these is being recognized? Capture a 'sh diag' and any relevant log messages.
