Embedded AP SSIS - Cisco 1941
Sep 19th, 2010
Can someone tell me the CLI configuration of the assinging the password WEP for SSID created on embedded AP in cisco 1941.
If so, then can we use WEP encryption on cisco 1941 AP ??
One more thing, I am getting message on SSID icon that "Information sent over this network might be visible to others" what does this mean and how to resolve this problem. Thanks
Surendra BG Sun, 09/19/2010 - 10:09
CLI configuration of the assinging the password for SSID created on  embedded AP in cisco 1941. If so, then can we use WEP encryption on  cisco 1941 AP ??
ANS -
en
config t
int dot11 0 or int dot11 1
encryption vlan mode wep mandatory
encryption key 1 size 128 or 40  (if used 128 bit then password will be 26 bit lenght and if 40 bit then its 10 bit password)
end
wr
the above will solve the first issue..
ANS -
This means that the SSID is getting broadcasted and any one who can scan for wireless signal can connect to it if the credentilas are known.. if you done want to broadcast then the person who connects to wireless should know the SSID to connect.. to make it invisible.. the below commend will do it..
en
config t
no guest-mode
end
wr
This will solve the second question..
Surendra
Related Content
Trending Topics - Security & Network
