ASA 5505 and 3660 Router
Sep 19th, 2010
Please help me out here....
I am stuck, I am trying to configure my home lab and I can't seem to find out how to do the following:
Internet -->ASA5505-->3660Router-->2900XL Switch --->ASA5505--->Wireless AP
Attached is an image  with a better idea of what I am wanting to do.
I have read that any router with the ASA is usless, but I would like to have the ASA just be a firewall/VPN and not much else.  Any help with this would be apprciated.
***All Cisco Equipment has basic configs loaded on them, if needed I can provide a show ver.
Nagaraja Thanthry Sun, 09/19/2010 - 14:53
  • Cisco Employee,
From the diagram, it seems like you would like to assign 192.168.1.x address all across the board. You cannot do it with a router in between. Different router interfaces should have different IP addresses. So, in your case, it could be 192.168.1.x on the LAN side of 3660 and 192.168.2.x on the firewall side.
On the ASA:
interface vlan 1
nameif inside
security-level 100
ip address 192.168.2.1 255.255.255.0
exit
interface Ethernet 1
switchport access vlan 1
exit
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
route inside 192.168.1.0 255.255.255.0 192.168.2.2
On the 3660:
interface FastEthernet 0/0
description connection to ASA5505
ip address 192.168.2.2 255.255.255.0
no shut
exit
interface FastEthernet 0/1
description connection to 2900XL
no shut
exit
ip route 0.0.0.0 0.0.0.0 192.168.2.1
In this case, you do not need to make any changes on the ASA for the outside interface or the NAT settings. You are just introducing another subnet on the inside to make sure that you do not need to change IP address settings on the LAN.
Hope this helps.
NT
woodjl1650 Sun, 09/19/2010 - 15:18
I did all the config as you stated but got this on the ASA
ASA2(config)# route inside 192.168.1.0 255.255.255.0 192.168.2.2
ERROR: Cannot add route, connected route exists
Not sure how to solve this.
Nagaraja Thanthry Sun, 09/19/2010 - 15:20
  • Cisco Employee,
Can you post the output of "show run interface" and "show run route" commands here?
NT
woodjl1650 Sun, 09/19/2010 - 15:42
Got the route comman to go, but now not internet access.  Cable modem is connected to 0/0
ASA Version 8.2(3)
hostname ASA2
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp setroute
interface Vlan5
no nameif
security-level 50
no ip address
ftp mode passive
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 192.168.2.0-192.168.2.36 netmask 255.255.255.0
route inside 192.168.1.0 255.255.255.0 192.168.2.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.2.5-192.168.2.36 inside
dhcpd dns 68.87.68.166 interface inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:1a1353fe23c3450240b068138904822d
: end
Nagaraja Thanthry Sun, 09/19/2010 - 15:50
  • Cisco Employee,
Please remove the following line:
the command is
no global (outside) 1 192.168.2.0-192.168.2.36 netmask 255.255.255.0
That should fix the internet connection issue.
NT
woodjl1650 Sun, 09/19/2010 - 16:11
removed it, but still no internet access....looking at my ip config on the PC, my default gateway is 192.168.1.1, is that correct?
Right now I have the cable modem ---> ASA 0/0 ---> ASA 0/1 ---->Router0/0----->Router0/1---->Switch 2900XL
Router Show Run
Router#show run
Building configuration...
Current configuration : 1244 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
enable secret 5 $1$.7Q9$mJ4Y0sVUoAw8QZ/33g1JD/
enable password henry999
no aaa new-model
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.1.1 192.168.1.7
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp pool 192.168.1.0/24
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
   dns-server 8.8.8.8 8.8.4.4
username woodjl privilege 15 secret 5 $1$w.xT$cFJweRcOx29N9hKafqu4h1
interface FastEthernet0/0
no ip route-cache
speed auto
full-duplex
interface FastEthernet0/1
no ip route-cache
duplex auto
speed auto
ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip forward-protocol nd
snmp-server community 192.168.1.1 RO
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
password henry
login local
end
Nagaraja Thanthry Sun, 09/19/2010 - 16:18
  • Cisco Employee,
Please issue the following command on the Router:
ip routing
Then, please issue the following command on the ASA:
clear xlate
This should clear out the incorrect xlate entries and allow internet connection.
Hope this helps.
NT
woodjl1650 Sun, 09/19/2010 - 16:40
still no internet.....grrr....any ideas?
ASA current show run
SA Version 8.2(3)
hostname ciscoasa
enable password DQucN59Njn0OjpJL encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address dhcp
ftp mode passive
pager lines 24
mtu inside 1500
mtu outside 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4 interface inside
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:59c3d18363d20a207a02bf8b79a27069
: end
woodjl1650 Sun, 09/19/2010 - 16:34
Sorry, here is the corret show run:
Current configuration : 1175 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no ip routing
no ip cef
no ip route-cache
speed auto
full-duplex
no ip route-cache
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
password henry
login local
end
woodjl1650 Sun, 09/19/2010 - 16:46
Show Run of the router after ip route command:
Current configuration : 1120 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
speed auto
full-duplex
duplex auto
speed auto
ip http server
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
password henry
login local
end
Nagaraja Thanthry Sun, 09/19/2010 - 17:20
  • Cisco Employee,
Can you try pinging 192.168.2.1 from any of the inside clients? If that works, that means the connection is good. Then please try to ping 4.2.2.2 from the ASA. That tells you if you have internet connectivity from the ASA or not. On the ASA, please try the following commands:
access-list outside_access_in permit icmp any any echo-reply
access-group outside_access_in in interface outside
Hope this helps.
NT
woodjl1650 Sun, 09/19/2010 - 17:39
I can ping the ASA and Router, but I don't get a reply from the internet.....
What could be wrong?
Thanks.
August Ritchie Sun, 09/19/2010 - 18:37
  • Bronze, 100 points or more
Just to clarify, did you try to ping 4.2.2.2 from the ASA itself?
Can you get a "show ip" and "show route" from the ASA?
Nagaraja Thanthry Sun, 09/19/2010 - 20:55
  • Cisco Employee,
Can you please try the following command:
icmp permit any outside
Then, try to ping 4.2.2.2 and see if that works.
NT
woodjl1650 Mon, 09/20/2010 - 00:22
Show IP
System IP Addresses:
Interface                Name                   IP address      Subnet mask     Method
Vlan1                    inside                 192.168.2.1     255.255.255.0   CONFIG
Vlan2                    outside                174.56.139.62   255.255.248.0   DHCP
Current IP Addresses:
Show Route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
       i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
       * - candidate default, U - per-user static route, o - ODR
       P - periodic downloaded static route
Gateway of last resort is not set
C    174.56.136.0 255.255.248.0 is directly connected, outside
S    192.168.1.0 255.255.255.0 [1/0] via 192.168.2.2, inside
C    192.168.2.0 255.255.255.0 is directly connected, inside
Ping 4.2.2.2
Sending 5, 100-byte ICMP Echos to 4.2.2.2, timeout is 2 seconds:
No route to host 4.2.2.2
Success rate is 0 percent (0/1)
August Ritchie Mon, 09/20/2010 - 02:10
Ahh, it looks like you have no default route.
Usually the command in the interfaces config for the outside "ip address dhcp setroute" will allow you to be assigned a default route by your ISP, but it either looks like that isn't happening or the ISP isn't sending that.
To remedy this you can add in
"route outside 0 0 " where next hop is the IP address of the ASAs next hop. You can find this out by doing either calling your ISP or taking a look at your "show arp" and see if there is another IP in the outside range (174.56.136.0 255.255.248.0) *Not really a surefire method, but can be faster than getting a hold of your ISP.
woodjl1650 Mon, 09/20/2010 - 02:59
Wow, Comcast is horrible with tech support....I am trying to explain what I need with no luck at all....
Should I just ask what the default route is? or is there something else I should be asking for?
August Ritchie Mon, 09/20/2010 - 07:12
Yeah, you should be asking what the IP address of the next hop should be, it should be in the 174.56.136.0 255.255.248.0 subnet. My guess is that it may be 174.56.136.1 as that is the first IP after the subnet ID, but this is just a common convention and may not be true in your case.
woodjl1650 Mon, 09/20/2010 - 12:50
Finally......it works...final question.  I would like to take the other ASA and put in between the phyical network and the wireless AP as shown in the picture above, is that overkill or smart sence it is dealing with wireless.  I want that more for intrustion detection....
Thanks.
August Ritchie Mon, 09/20/2010 - 14:19
Design questions are a little bit trickier as we can't really know the full scenario of your network, I.E. what you want the wireless for, is it just a guest network, do you need inside users to access it. Do you consider it to be more or less secure than the inside?
I'll throw out an idea, not a professional recommendation, but you may want to look into placing this as a DMZ on your current ASA depending on your license and whether you want the inside to communicate with it or not.
There are just so many unknowns to the scenario that we just can't say what is best.
woodjl1650 Mon, 09/20/2010 - 14:34
No DMZ on my license ...just an extra one I have...my network is a home network that I just want secure.  So I was wondering if the ASA would provide that with the access point connected to it.
August Ritchie Mon, 09/20/2010 - 14:56
Adding another security device might add a small amount of protection. To me, this firewall would mean that you don't trust the rest of the objects in the 192.168.1.0 network and want to restrict their access to your wireless network. I would guess that if you do trust them, then the firewall isn't going to do much as the internet facing firewall should be doing all the filtering that the second firewall would do.
Another thing you have to consider is your addressing scheme:
1. If you want to keep the 192.168.1.0 on both sides of the second ASA you will need to run it in transparent mode.
2. If you decide that you want to keep it the second ASA in routed mode, you may run into asymmetric routing issues.
