hairpinning in asa5510
Sep 19th, 2010
Hi all,
I have a cisco asa 5510 whose inside interface has a ip of 192.168.5.1. I have a pc with the ip of 192.168.5.2 and uses gateway 192.168.5.1. I need the asa firewall to be able route traffic from the pc for certain networks(eg 192.168.6.0/24 and 192.168.7.0/24) to a router 192.168.5.3. I have configured the appropriate static route on the asa and have enabled hairpinning using "same-security-traffic permit intra-interface" (so that traffic can enter and exceed the same interface) but the routing fail to work. What other config is required? Pls advise, thks in advance.
Nagaraja Thanthry Sun, 09/19/2010 - 15:01
If you are running pre-8.2 image on the ASA, please try the following:
global (inside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 <-- This line may already be there
If you are running 8.2 or higher code version, then
access-list bypass permit ip 192.168.5.0 255.255.255.0 192.168.6.0 255.255.255.0
access-list bypass permit ip 192.168.5.0 255.255.255.0 192.168.7.0 255.255.255.0
class-map TCP_bypass
match access-list bypass
exit
policy-map inside_policy
class TCP_bypass
set connection advanced-options tcp-state-bypass
exit
service-policy inside_policy in interface inside
This will ensure that the firewall supports asymmetric routing. In the first option, only 192.168.5.x is allowed to initiate the connection while the second one will work for bidirectional connections.
Hope this helps.
NT
donnie Mon, 09/20/2010 - 13:03
Hi NT,
i am using pre asa 8.2 version and I need it to work bi directional. Pls advise. THks in advance.
Nagaraja Thanthry Mon, 09/20/2010 - 13:15
In that case, you need to make the inside router as the default gateway for the 192.168.5.x subnet. You can set ASA as the default gateway for the inside router.
NT
Allen P Chen Mon, 09/20/2010 - 16:38
What software version is the ASA 5510 running?  If it is running 7.0 or 7.1, the command "same-security-traffic permit intra-interface" applies to IPSec traffic only.  This command applies to all traffic in software version 7.2 and later.
donnie Mon, 09/20/2010 - 13:27
Hi NT,
I have applied the following.
"global (inside) 1 interface" while "nat (inside) 1 0.0.0.0 0.0.0.0" is already in my config.
But my pc still can't initiate session to 192.168.6.0/24 and 192.168.7.0/24 subnet. Pls advise.
