This discussion is locked
WAP4410N settings to use as a range extender
I have a simple wireless network that works fine, except for one room where the signal is too low. So I purchased a WAP4410N to use as a range extender.  would you please provide the exact settings that are need to set this up?  I have tried many, many different configurations, and I can't get it to work properly.  In particular, it will not give me an IP address and therefore won't connect.  Also, is it important to use the SAME SSID name?  or better to use a different name so as not to confuse the two signals (base unit vs repeater (4410)).  Appreciate your advice
cindy toy Thu, 10/14/2010 - 14:40
Hi Bill,
I noticed that this same question was posted in this thread from you: https://supportforums.cisco.com/message/3202137
I will close this thread so that everyone can just follow the one above since you have received a couple of replies in the other thread.
Best regards,
Cindy Toy
Cisco Small Business Support
Community Manager
