Ciscoworks LMS 3.2 Queries
Sep 19th, 2010
     I need to know if Ciscoworks LMS 3.2 supports the following.
    1) Forwarding of events/alerts to SMS instead of just SMTP?
    2) When the event/alert is cleared, will DFM be configurable to send an update through SMTP/SMS?
Overall Rating: 4 (1 ratings)
Joe Clarke Sun, 09/19/2010 - 21:51
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
No, LMS cannot send directly to SMS.  If you have an SMTP to SMS gateway, you can use that.  Yes, DFM can be configured to send an SMTP notification when an event/alarm is cleared.
xs.gautam Mon, 09/20/2010 - 04:13
In your response to above queries, if u can suggest us how can we achieve this.
A little insight to same is appreciated. We have a SMSC gateway if we can configure it for this to work ?
Joe Clarke Tue, 09/21/2010 - 21:59
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
The way LMS sends notifications your gateway would need to support standard email addresses.  In that case, you'd just setup a standard SMTP gateway in LMS, then specify your SMS email addresses for your notifications.  For example, AT&T allows one to send email to [email protected] to turn email into text messages.  This is the kind of interface LMS would require.
brandon.wcj Wed, 09/22/2010 - 01:50
How do I check if the msg is really sent out to the SMTP server?
