Call Handler transfer any extension
Sep 19th, 2010
Hi!
I have configured a Call Handler and this working now, but this only transfer to extension of the subscribers of unity, I can not tranfers to extension without voice mail
Any body now how can I do it?
Marco
Overall Rating: 3.7 (3 ratings)
Jaime Valencia Sun, 09/19/2010 - 20:42
  • Cisco Employee,
  • Hall of Fame,
    2011
From a regular call handlet you can't, that's WAD. You need to use  a call system transfer if the DN you want to dial is not in Unity's DB as a subscriber, call handler, etc.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
philip.e.denton Tue, 09/21/2010 - 05:51
  • Silver, 250 points or more
Also make sure the CSS of the Unity (Connection) ports allows calling any destination that you allow within the actual caller system transfer rules.
fernandoaguirre Mon, 02/27/2012 - 09:18
Hi javalenc,
I'm trying to do the same as Marco. Do you have a document or more detailed steps on how to setup AutoAttendant on Unity 4.2 to transfer to any extension and not only to Unity Subscribers? How do I setup a call system transfer??
Thanks!
Fernando A.
Jaime Valencia Mon, 02/27/2012 - 09:43
  • Cisco Employee,
  • Hall of Fame,
    2011
Caller systems transfer is just an option from the dropdown menu you configure under caller input.
Just as you can transfer to another call handler, subscriber, etc. Select caller system transfer and that's it.
You can also configure it under routing rules, but bottomline, it's just an option from the dropdown menu you need to select.
java
shaftstri Tue, 09/21/2010 - 04:17
In Unity Connection 7.x
In the call handler there is option under greeting
Example Edit greeting standard
See
Allow Transfers to Numbers Not Associated with Users or Call Handlers
Times to Re-prompt Caller
try that and let us know how it go's
mrmhar1408 Tue, 03/29/2011 - 03:54
also after you check box Allow Transfers to Numbers Not Associated with Users or Call Handlers
you have to allow to dial extension from Restrictions table for example if you have extension 4 digits you need to allow calls for ????
Jaime Valencia Tue, 03/29/2011 - 06:44
  • Cisco Employee,
  • Hall of Fame,
    2011
Yes, the restriction tables need to be adjusted accordingly.
Allow Transfers to Numbers Not Associated with Users or Call Handlers—
Check this check box to allow callers to transfer to extensions that are not assigned to other users or call handlers. Connection attempts a release transfer as long as the number entered by the caller is allowed by the Default System Transfer restriction table.
java
ahmed-hassan1110 Mon, 03/27/2017 - 03:20
After enabling "Allow Transfers to Numbers Not Associated with Users or Call Handlers" in the greeting, try the following, Go to System Settings> Restriction Tables> Default System Transfer and uncheck the * pattern checkbox.
