wallboard for uccx8 config ?
Sep 19th, 2010
Hi guys
does anyone have experience setup Wallboard working with UCCX8 ?
I was followed the doc from Cisco setup successed for the database connection between wallboard user and uccx8 .
i don't know what's next stage ... ?
Anthony Holloway Mon, 09/20/2010 - 08:29
Wow, that's pretty good.  It took me a while to find the documentation necessary to get that far.  Good job.
So, are you integrating with a real wallboard?  e.g., Wall handing led matrix marquee?
Or are you going web based?
ausjustin Mon, 09/20/2010 - 08:54
yes, i did
and today just make the real wallboard working ....
so as long as DSN working then the real wallboard setup should easy than UCCX7.
Anthony Holloway Mon, 09/20/2010 - 14:00
Well, not really.  Your wallboard software has to know about the REST API to see which server has DB mastership.
Do you know if your wallboard supports UCCX 8?
ausjustin Mon, 09/20/2010 - 19:50
yes, it is working .
but i am not user how can use REST API for support DB ?
do you know that ?
