09-19-2010 08:51 PM - edited 03-04-2019 09:49 AM
Hello folks -
I am using a route-map in BGP to filter some routes from an eBGP neighbor. However, the filtering is not working as expected.
Not sure where am I going wrong. Below is the config.
ip prefix-list deny_rsa seq 5 permit 10.20.30.0/24
ip prefix-list deny_rsa seq 10 permit 10.20.40.0/24
route-map test deny 10
match ip address deny_rsa
route-map test permit 20
router bgp 11
no synchronization
bgp log-neighbor-changes
network 10.10.12.0 mask 255.255.255.0
neighbor 10.10.12.1 remote-as 11
neighbor 10.10.12.1 route-map test in
no auto-summary
Essentially, I am trying to filter 10.20.30.0/24 & 10.20.40.0/24 but somehow this config is not working as expected.
Can any one tell where is my logic wrong?
Thanks for your help.
Solved! Go to Solution.
09-19-2010 11:04 PM
You have a small error in your route-map - your route-map refers to an ACL deny_rsa which does not exist, instead of referring to a prefix-list. Correctly, your route-map should be:
match ip address prefix deny_rsa
Don't forget to perform the clear ip bgp * in command after you modify or apply the route-map.
Best regards,
Peter
09-19-2010 11:04 PM
Best regards,
Peter
09-20-2010 09:43 AM
Thanks for your reply Peter. That did the trick!!
