Re-Install the CUCM v6
Sep 19th, 2010
I need to re-program the cucm from the scratch.
1.What all factors I need to take in to consideration while doing this.?
2. How to back up the licenses? --- as the licence files are mising.
Faizal
Joseph Martini Mon, 09/20/2010 - 00:40
  • Cisco Employee,
I'll assume you're rebuilding your publisher.  In that case you can really do anything you want during the install if you're going to be configuring it from scratch you can use any IP address or hostname you want.  If you were restoring a backup you would have to install it using the same hostname and IP address as the original or else the restore would fail.  As far as licenses if you have a backup they're backed up, but if you do not and you don't have them saved somewhere other than on the server you can open a TAC case with the licensing group and they can send you the same license files again the server already had.
