UCCX Terminate Step
ahochau_2
Greetings,
I was once told that any script that begins with accepting a contact **MUST** end with a terminate.  Is that true?
Mark
ahochau_2
Found my own answer in the course book.  Yes, I need a terminate step.
There's is no requirement that you must Terminate a contact, or that the step simply has to exist in the script.
Take a look at this completely valid example:
start
on exception contact inactive exception goto contact inactive
play greeting
menu choices:
  1 - hours and directions
    play hours and directions
  2 - specials
    play specials
  timeout
    play i did not receive a response
  unsuccessull
    play that is an invalid choice
goto menu choices
contact inactive:
end
or this one:
start
play greeting
menu choices
  1 - billing
    set transfer = 1000
  2 - sales
    set transfer = 2000
  3 - support
    set transfer = 3000
  timeout
    set transfer = 0
  unsuccessful
    set transfer = 0
call redirect to transfer
  successful
  busy
  invalid
  unsuccessfull
end
We can simply use 'end' to end the script here.  If the caller was successfully transferred, the contact is no longer active, so 'end' is appropriate.  If the caller failed to transfer, e.g., busy, invalid, unsuccessful, ending the script without terminating the contact leads to a contact inactive exception being thrown and the default script executing.  which in many cases is simply a call redirect to "system problems".
So combining your examples with the information from the course book it looks like answer is a "Should" not a "Must"?
It's "could."
Some IVR's are designed to not hangup on callers, but instead, wait for callers to hangup on it.  If that is the case, then you don't need a terminate step.
So the answer is "could" rather than "must" or "should."  At that point you may as well delete the sentence from the book.  Because any step "could" be in the script.
