CUCM6.1 - dbreplication errors
Answered Question
Sep 20th, 2010
Facts:
Cluster with Publisher and 1 Subscriber all with CUCM Version: 6.1.4.2000-2
Because of an inconsistencies in the file system I had to reinstall the publisher.
After that I restored the Backup.
The System is up and running.
But now I have problems with the dbreplication:
I get the error in CiscoSyslog:
: 11011: Sep 20 08:18:58.741 UTC : %CCM_DB_LAYER-DB-3-IDSReplicationFailure: Combined alarm for emergency and error situations. IDS Replication has failed Event Class ID:Realtime Replication is broken Event class message:replstate = 3 Event Specific Message:Please run utils dbreplication status from publisher Cluster ID:StandAloneCluster Node ID:CUCM6-P
I checked the dbreplication status:
admin:file view activelog cm/trace/dbl/sdi/ReplicationStatus.2010_09_20_09_04_32.out
SERVER                 ID STATE    STATUS     QUEUE  CONNECTION CHANGED
g_cucm6_p_ccm6_1_4_2000_2    2 Active   Local           0
utils dbreplication status output
To determine if replication is suspect, look for the following:
        (1) Number of rows in a table do not match on all nodes.
        (2) Non-zero values occur in any of the other output columns for a table
        (3) ***** PLEASE IGNORE MISMATCHES IN ReplicationDynamic TABLE *****
Processing ccmdbtemplate_cucm6_p_ccm6_1_4_2000_2_1_86_typedberrors with 803 rows group 1
Error returned 99 at 1342
Error returned 99 at 823
command failed -- *Error* <99> is not a known Enterprise Replication error (99)
// How can I have a look to these errors or resolve them?
admin:show perf query class "Number of Replicates Created and State of Replication"
==>query class :
- Perf class (Number of Replicates Created and State of Replication) has instances and values:
    ReplicateCount  -> Number of Replicates Created   = 393
    ReplicateCount  -> Replicate_State                = 3
Here is the Unified CM Database Status Report with errors (also as attachment)
How can I fix/sync these files?
I did all the stuff which I could find in the world wide web.
The only thing which I haven't done is
utils dbreplication forcedatasyncsub
Have somebody tried out this command before?
Is the Publisher working fine in that time of sync process?
Correct Answer by kusatija about 6 years 9 months ago
Hi Marcus,
Please reboot the publisher first and then subscriber in down time, and then provide us fressh snap shots of the unified reporting.
Kunal
Overall Rating: 5 (1 ratings)
kusatija Mon, 09/20/2010 - 04:33
  • Silver, 250 points or more
hello,
Try the following in the exact same sequence below:
>>utils dbreplication stop on the subscriber
>> once it is stopped on the subscriber then utils dbreplication stop
on the publisher
>> wait for a few minutes for it to finish
>> utils dbreplication dropadmindb on the publisher
>> wait for it to finish
>> utils dbreplication dropadmindb on the subscriber
>>utils dbreplication reset all on the publisher
Give it some time and then run the following:
on both the servers to see if the replication status moves to 2 on both the servers.
kunal
kusatija Mon, 09/20/2010 - 04:35
Just had a look at the screen shot provided, the rhost and the sql hosts files on the servers dont match, might need root access to edit the files.
Please open a TAC case so we can fix this.
kunal
Marcus Hunold Mon, 09/20/2010 - 04:49
Thank you for your answers.
How does it happen that the rhost and the sql hosts files on the servers dont match?
Which of these Server Publisher/Subscriber have the right files?
Have I configured something (when yes - what?) wrong through the reinstallation process?
I have finished all thinks before I had reconneted the Publisher to the network...
My problem is that I have no contract for this cluster so I can't open a TAC case
kusatija Mon, 09/20/2010 - 04:58
Hi Marcus,
192.168.0.2 ------> rhosts file does not contain the entry of CUCM6-S
Confirm the IP address/Hostname of both the servers.
He the files got messed up, there could be many reasons.
With out having root access, and editing the files, i do see the replication coming up.
Has a reboot of the publisher and then subscriber been tried?
Kunal
Marcus Hunold Mon, 09/20/2010 - 05:16
Since I have reconnected the Publisher to the network, I never have rebooted it.
The Subscriber I have rebooted after that.
Ok I will try the reboot from the Publihser and after the Subscriber.
But I can only do this during a slack period. :-/
But it is weird that Unified CM Cluster Overview is fine and the others not...
Correct Answer
kusatija Mon, 09/20/2010 - 05:32
Hi Marcus,
Kunal
Marcus Hunold Wed, 09/22/2010 - 04:27
Hi Kunal,
I have rebooted the cluster.
After that I followed "Database Replication Error in Cisco Unified Communication Manager 6.1.pdf"
and now it is working fine :-)
Thank You very much for your help!
