Callmanager 6 - matching e.164 called numbers
Sep 20th, 2010
Hello Community,
I am wondering whether Callmanager Version 6 understand the e.164 format? I would like to integrate the feature dialing from outlook, but most of the numbers have a + sign included. I thought I could match on "+, which the system denied. Is there another option to get these both applications work together?
Thanks!
Overall Rating: 5 (2 ratings)
Joseph Martini Tue, 09/21/2010 - 10:37
  • Cisco Employee,
CUCM 6 does not support e164 (+), this was first supported in 7.x.  Dialing through outlook typcailly comes through CTI using JTAPI so you can try and use Application Dial Rules to strip the + and then route the call.  I've never tested this out so I'm not sure if you'll even get the number with a + far enough into CUCM to hit the application dial rule.  Alternatively depending on what tool or application you're using to dial from outlook you might be able to put a dial rule there.
Aaron Harrison Tue, 09/21/2010 - 14:30
  • Community Spotlight Award,
    Member's Choice, May 2015
Joe is correct; you can use app dial rules in 6.x to strip the + character, and replace it with appropriate characters (e.g. typically 9, 90 or 900 depending on length in the UK, your country may vary).
App Dial Rules are very poorly implemented in CUCM, and they can be tricky to set up for variable length plans like you get most places outside the US... but it is usually workable.
Aaron
Please rate helpful posts...
tschmolcz Wed, 09/22/2010 - 05:45
Thanks guys, I'll take a look at it and keep you informed wether it was helpful for me.
