Configuring RV082 and Load balance
Sep 20th, 2010
Hello everyone,
I'm asking for your help in order to configure my RV082. Here my problem :
The RV082 is between an ISA server 2006 and 2 Internet Box with Static WAN IP Address.
I didn't find the right configuration in order to have the 2 Internet connections simultaneously.
Here the network configuration :
ISA server 2006 :
External NIC IP : 10.0.101.253
Gateway : 10.0.101.250
RV082 :
Static Ip address : 10.0.101.250
WAN 1 : 81.89.63.61
WAN 2 : 10.0.101.1
Box Internet 1:
Static Ip Address : 10.0.101.254
Wan Ip : 81.89.63.61
Box Internet 2:
Static Ip Address : 10.0.101.251
Wan Ip : 89.158.92.61
I'm only able to have one Internet connection at a time and really can't find the right configuration to have the 2 connections up and add their bandwith. If needed i can give more details.
If someone could help me or give me some advice I would be really thankful.
riroe Mon, 09/27/2010 - 04:38
I would suggest that you call into our Cisco Small Business Support Center (1-866-606-1866) and open up a case to assist you in
your configuration. We will need the serial number of the router when you call to check entitlement.
THANKS
