MTU Cisco and Juniper
Sep 20th, 2010
Hello we have site to site connetions on a layer2 domain.
So
cisco3560<----Layer 2 Hardware Encrytor-->ME3400-2CS-A<---Dot1Q tunnel--->ME3400-2CS-A<---LAyer 2 Hardware Encryptor---->Juniper EX 4200
I-am receiving Latencies from copynig from clients on juniper to clients to Cisco. The other side is ok.
MTU Jumbo on ME 3400 is 1800. Link is Gigabit. I havent changed the mtu on Encryptor and on Cisco nor Juniper .
As I googled and saw Juniper and Cisco have diffrent MTU 1518 on Juniper and 1500 on Cisco.
On Wireshirek I see TCP Previous segment lost, TCP Duplicate and TCP Fast retranssmission.
Any advice for this situation you think this is Fiber problem or MTU.
To be Clear everything worked k isnce two weeks before
Giuseppe Larosa Mon, 09/20/2010 - 07:03
  • Hall of Fame,
    Founding Member
Hello Enkli,
on EX 4200 1518 refers to the L2 MTU that is the ethernet frame size, so this shouldn't be a problem as ip mtu is 1500 bytes for both
Hope to help
Giuseppe
enkli Sat, 09/25/2010 - 11:05
Giuslar thank you very much for you reply.
To be more clear. The design is like that
(A)C3560<-->Hardware encryptor<--->dot1Q ME3400G<--DarkFiber-->dot1Q ME3400G<--->Hardware encryptor<--->C3560(B)
        DarkFiber
        Dot1Q ME3400G
        Hardware encryptor
        Juniper EX4200(C)
Everything was fine before
Now I am able to copy in full speed from any computer at site C to/from site B and vice versa
Now I am able to copy in full speed from any computer at site A to/from site B and vice versa
Bu I can copy form site C and A but I am not able to cop[y to site A. I see loss of packets even inside VLAN
Have you any idea her might be the problem in the interconnecting switch ME3400 at junipers might be some loop cause i dont see packets on trunk interface of Juniper outgoing just 1 or 2 Mbps. I have done test on fiber from telecom and they say it is fine.
Enkli
Reza Sharifi Sat, 09/25/2010 - 11:14
  • Cisco Designated VIP,
    2017 LAN
Hi Enkli,
What type of encryption device are you using?
Reza
enkli Sat, 09/25/2010 - 12:13
I dont think there might be a problem. we are using Cipherop
tics layer 2 encryptors
Ali Norouzi Wed, 12/22/2010 - 23:02
Do you have problem from site A to C? Have you bypassed encryptors to make sure about them? Have you measured path MTU by ping and setting DF value?
