VS-S720-10G-3C Ethernet Modules Compatibility
Answered Question
Sep 20th, 2010
I have a WS-C6509 chassis with the following modules: 2x WS-X6K-SUP1A-2GE; 3x WS-X6408A-GBIC; 1x WS-X6516A-GBIC; 1x WS-X6348-RJ-45 and WS-X6148-GE-TX.
We want to replace the supervisors with the VS-S720-10G-3C. How can I confirm that all modules are supported with these supervisors?
Regards.
Correct Answer by Jon Marshall about 6 years 10 months ago
Regards.
Claudia
The release notes are the place to check these sort of things -
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/release/notes/ol_14271.html
The answer to your question is that they are all supported with the VS-S720-10G-SC supervisor running 12.2(33)SXH or later as long as you are not running VSS. If you are planning to run VSS then none of them are supported as you need 67xx modules for VSS.
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Mon, 09/20/2010 - 06:04
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Regards.
Claudia
Jon
