IPSEC VPN betwwwn ASA and ISA server problem
Sep 20th, 2010
Hi all, thank u for your help.
I tried to establish Ipsec vpn b/n ASA and ISA server, but i have got the following error:
[IKEv1]: Group = x.x.x.x, IP =
x.x.x.x, Can't find a valid tunnel group, aborting...!
Sep 20 05:56:15 [IKEv1]: Group = x.x.x.x, IP = x.x.x.x, Removing peer
from peer table failed, no match!
Sep 20 05:56:15 [IKEv1]: Group = x.x.x.x, IP = x.x.x.x, Error: Unable
to remove PeerTblEntry
Sep 20 05:56:15 [IKEv1]: IP = x.x.x.x, Header invalid, missing SA payload!
(next payload = 4)
The security life time is the same on both sides.
Any help please
praprama Mon, 09/20/2010 - 06:29
  • Cisco Employee,
It seems like you do not have a tunnel-group configured with the ISA server's public IP address. Please check the output of "show run tunnel-group" from the ASA. If the ISA's IP address is a.b.c.d, you should see the below:
tunnel-group a.b.c.d type ipsec-l2l
tunnel-group a.b.c.d ipsec-attributes
pre-shared-key PSK
Please aste the output here.
Thanks and Regards,
Prapanch
mulugojjam abebe Mon, 09/20/2010 - 07:29
Thank you Prapanch,
Now its working i changed the tunnel-group name with the remote ip address and it works.
previously it was tunnel-group remotevpn, and now i changed tunnel-group a.b.c.d
Thank you fro your help,
Mulu
