Is Router Bridging My Only Option?
Sep 20th, 2010
Hi all,
I've been reading through this support community for about a week now and found  many discussions similar to my question about using fa/0 & fa/1 on my 2811's.
Attached is a drawing of our typical remote locations.  Left side is current configuration, right side is what I'm trying to accomplish.  Basically one 2811 router and two 3560 switches, and I'm looking for some type of solution that would keep switch2 up should switch1 fail.  All Vlans (voice, data, and soon wireless AP) on both switches.
Jon Marshall Mon, 09/20/2010 - 08:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
mchiaravalle wrote:
Hi all,
You could bridge but if these are 3560 switches then they are capable of routing. So what i would do is make the links between the 3560 switches and the 2811 router L3 P2P routed links, run a dynamic routing protocol such as EIGRP between the 3560s and the 2811 and then if one switch fails the other will continue to pass traffic. Your HSRP/GLBP if you are running it, would be on the 3560 switches eg -
router 2811
int fa0/0
ip address 192.168.5.1 255.255.255.252  <-- to switch1
int fa0/1
ip address 192.168.5.5 255.255.255.252 <--- to switch 2
router eigrp 1
network 192.168.5.0 0.0.0.7
no auto-summary
switch1
int gi0/1
no switchport
ip address 192.168.5.2 255.255.255.252
router eigrp 1
network 192.168.5.0 0.0.0.3
+ the vlans/subnets for the clients on the 3560 switch
no auto-summary
switch 2
int gi0/1
no switchport
ip address 192.168.5.6 255.255.255.252
router eigrp 1
network 192.168.5.4 0.0.0.3
+ vlans/subnets on the 3560 switch
no auto-summary
Note, as i am sure you are aware, any device that is only singly connected to one of the 3560 switches will lose it's connection if the switch fails ie. your diagram shows an AP connected to switch1. If switch1 fails then you have lost the AP.
Jon
mchiaravalle_2 Tue, 09/21/2010 - 09:16
HI,
Thanks for the quick response and sorry for my late response.  I think I understand most of your config and will give it a try as soon as I can and let you know.
Nagaraja Thanthry Mon, 09/20/2010 - 08:18
  • Cisco Employee,
You can configure HSRP at the switch level and then configure different default gateways on each switch. In that way, when the link between the switch 1 and the router goes down, Switch 2 will takeover and then route the traffic via 2800 to internet.
On the switch 1:
interfaceVLAN 1
description Data VLAN
ip address 192.168.1.2 255.255.255.0
standby 1 ip 192.168.1.1
standby 1 priority 254
standby 1 preempt
standby 1 mac-address 0020.2222.1111
interfaceVLAN 2
  description Voice VLAN
  ip address 192.168.2.2 255.255.255.0
  standby 2 ip 192.168.2.1
  standby 2 priority 254
  standby 2 preempt
  standby 2 mac-address 0020.2222.2222
interface VLAN 3
description Connection to 2800
ip address 192.168.3.2 255.255.255.240
interface FastEthernet 0/24
switchport access vlan 3
ip route 0.0.0.0 0.0.0.0 192.168.3.1
On the Switch 2:
interfaceVLAN 1
  ip address 192.168.1.3 255.255.255.0
  standby 1 priority 100
  standby 1 preempt
interfaceVLAN 2
  ip address 192.168.2.3 255.255.255.0
  standby 2 ip 192.168.1.1
  standby 2 priority 100
  standby 2 preempt
interface VLAN 3
ip address 192.168.3.130 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.3.129
On the Router:
interface FastEthernet 0/0
description Connection to Switch 1
ip address 192.168.3.1 255.255.255.240
ip nat enable
interface FastEthernet 0/1
description Connection to Switch 2
ip address 192.168.3.129 255.255.255.240
ip nat enable
interface serial 0/0
description Connection to internet
ip address
no ip nat outside
ip nat enable
ip route 192.168.1.0 255.255.255.0 192.168.3.2 track 1
ip route 192.168.2.0 255.255.255.0 192.168.3.2 track 1
ip route 192.168.1.0 255.255.255.0 192.168.3.130 254
ip route 192.168.2.0 255.255.255.0 192.168.3.130 254
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 10 permit 192.168.2.0 0.0.0.255
ip nat source list 1 interface Serial 0/0 overload
track 1 ip sla 1 reachability
delay down 10 up 30
ip sla 1
icmp-echo 192.168.1.2
ip sla schedule 10 life forever start-time now
Hope this helps.
NT
mchiaravalle_2 Tue, 09/21/2010 - 09:19
HI Nagaraja,
Thanks to you and Jon I have some good configs to work from.  Sorry for my late response back to you.  As soon as I get working on this I'll let you know how it goes.
Again thanks!
