MGCP E1 PRI Port Registration Issue
Answered Question
Sep 20th, 2010
i'm trying to register 6 E1 PRI ports of  VWIC2-2MFT-T1/E1 cards. I use:
- CUCM 7.1.3
- 3845 Voice gateway
- 3 VWIC2-2MFT-T1/E1 Cards
I followed all guidelines:
- i checked the right Router name and set the IP domain on both Gateway and Call Manager
- Configured the CUCM gateway page
The Gateway gets all configuration from CUCM ( i see mgcp commands downloaded on Router config) and i can see the Gateway IP on the "device---> gateway" page showing the ports. My problem is that the ports are not registered: i noticed that, when Gateway roboots, the ports appeared registered for few seconds but they come back to the unregistered status quickly.
My questions are 2:
- the issue can be caused because i don't have physical connection to PSTN ? I mean that my PRI ports are not connected to telco line
- My gateway is brand new: is there any configuration i must do on the cards/ports before start the MGCP registration process. The only manual configuration i did is the command "card type e1 0 0", "card type e1 0 1", "card type e1 0 2" after installing the cards for the first time in my router.
Thank you,
Roberto
Correct Answer by Jaime Valencia about 6 years 5 months ago
That's expected since you don't really have anything connected.
Once you plug in the telco cable they should register in CUCM.
I'm assuming all your MGCP config is correct for the above to happen.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 09/20/2010 - 09:19
java
robmas0871 Mon, 09/20/2010 - 10:45
Hi Javalenc,
thank you for reply. Do you think the command "card type e1 0 0" is enough to initialize a brand new card in a new Router or can i add some other to better prepare hardware to MGCP configuration ?
Thank you,
Roberto
Jaime Valencia Mon, 09/20/2010 - 10:57
Full examples of config are here:
How to Configure MGCP with Digital PRI and Cisco  CallManager
http://www.cisco.com/en/US/partner/tech/tk1077/technologies_configuration_example09186a00801ad22f.shtml
Configuring the Cisco IOS MGCP Gateway
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps556/products_tech_note09186a008017787b.shtml
java
mshamkumar Thu, 10/14/2010 - 08:44
Priority        Status                   Host
Primary         Down                     10.200.1.10
First Backup    Down                     10.200.2.10
Second Backup   Down                     10.200.3.10
Current active Call Manager:    None
Backhaul/Redundant link port:   2428
Failover Interval:              30 seconds
Keepalive Interval:             15 seconds
Last keepalive sent:            03:04:53 UTC Oct 14 2010 (elapsed time: 12:34:44)
Last MGCP traffic time:         13:08:34 UTC Oct 14 2010 (elapsed time: 02:31:03)
Last failover time:             13:09:34 UTC Oct 14 2010 from (10.200.1.10)
Last switchback time:           13:10:04 UTC Oct 14 2010 from (10.200.3.10)
Switchback mode:                Graceful
MGCP Fallback mode:             Not Selected
Last MGCP Fallback start time:  None
Last MGCP Fallback end time:    None
MGCP Download Tones:            Disabled
TFTP retry count to shut Ports: 2
Configuration Auto-Download Information
Current version-id: 1286217727-28721f44-9975-4e95-9c42-56d360489c13
Last config-downloaded:00:00:00
Current state: Waiting for commands
Configuration Download statistics:
        Download Attempted             : 1
          Download Successful          : 1
          Download Failed              : 0
          TFTP Download Failed         : 1
        Configuration Attempted        : 1
          Configuration Successful     : 1
          Configuration Failed(Parsing): 0
          Configuration Failed(config) : 0
Last config download command: New Registration
FAX mode: cisco
What i am missing and what is the problem.......
