cisco 1700 series router failing to load IOS
Jerome2010
guys kindly assist me. find the message i am getting when trying to boot my 1700 series router.
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
program load complete, entry point: 0x80008000, size: 0x569578
Self decompressing the image : #################################################
############################################### [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
MainBoard       0X00027A80 1721
               0X000F3BB0 public buffer pools
                0X00211000 public particle pools
0X0039          0X0000DC00 Card in slot 0
TOTAL:          0X0033A230
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Allocating additional 8025254 bytes to IO Memory.
PMem allocated: 55699754 bytes; IOMem allocated: 11409110 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(9), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 14-May-04 15:39 by dchih
Image text-base: 0x80008120, data-base: 0x809F6618
%Software-forced reload
Unexpected exception to CPUvector 700, PC = 8020306C
Unexpected exception to CPUvector 1200, PC = 802933D8
Nagaraja Thanthry
It seems like a software failure. Please upgrade the image on the router.
NT
thank you Nagaraja. i have upgraded the IOS with a version that is currently runninf on one of my routers but the upgraded version is not loading again. jsut have a look at what i have done and the error that is coming out below:
monitor: command "boot" aborted due to user interrupt
rommon 1 > IP_ADDRESS=192.168.100.16
rommon 2 > IP_SUBNET_MASK=255.255.255.0
rommon 3 > DEFAULT_GATEWAY=192.168.100.247
rommon 4 > TFTP_SERVER=192.168.100.247
rommon 5 > TFTP_FILE=c1710-k9o3sy-mz.122-15.T2.bin
rommon 6 > tftpdnld
          IP_ADDRESS: 192.168.100.16
      IP_SUBNET_MASK: 255.255.255.0
     DEFAULT_GATEWAY: 192.168.100.247
         TFTP_SERVER: 192.168.100.247
           TFTP_FILE: c1710-k9o3sy-mz.122-15.T2.bin
Invoke this command for disaster recovery only.
WARNING: all existing data in all partitions on flash will be lost!
Do you wish to continue? y/n:  [n]:  y
Receiving c1710-k9o3sy-mz.122-15.T2.bin from 192.168.100.247 !!!!!!!!!!!!!!!!!!!
File reception completed.
Copying file c1710-k9o3sy-mz.122-15.T2.bin to flash.
Erasing flash at 0x61fe0000
Programming location 607c0000
rommon 7 > reset
program load complete, entry point: 0x80008000, size: 0x7c10fc
############ [OK]
  ID            MEMORY_REQ         TYPE
TOTAL:          0X0033A230
Allocating additional 5918368 bytes to IO Memory.
PMem allocated: 57806640 bytes; IOMem allocated: 9302224 bytes
           cisco Systems, Inc.
IOS (tm) C1700 Software (C1710-K9O3SY-M), Version 12.2(15)T2,  RELEASE SOFTWARE
(fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 01-May-03 09:34 by nmasa
Image text-base: 0x80008120, data-base: 0x80E98D6C
Unexpected exception to CPUvector 700, PC = 801F57CC
-Traceback= 801F57CC
Free space check for flash:crashinfo_19930301-000002 failed (-1/349)
Queued messages:
*** System received a Software forced crash ***
signal= 0x17, code= 0x700, context= 0x815df7b8
PC = 0x801f57cc, Vector = 0x700, SP = 0x818317e0
it then continue to decompress the image and get to this point and restart again
