PADI Timer Expired... how to debug
jquintard
My router is configured to open a PPPoE session with a modem in RFC2684.
I have two ADSL lines, each on the same ISP.
If I try to open the session with the first line, no problem.
If I try to open the session with the second : Padi Timer Expired !
In each case, my modem is synchronize to the DSLAM.
How I can debug the padi timer expired to understand with I not the pado from the ISP ?
My ISP think is a collect problem (the first is probably collected in IP the second in ATM). In this case what is the solution to doing that (I have no ATM interface on my router..).
Jerome
Giuseppe Larosa
Hello Jerome,
follow the procedure described here:
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a008071a7c2.shtml
this means both lines are up/p at DSL level, but the two lines can have different encapsulations for example and you need two modems one for line1 and one for line2.
see also
http://www.faqs.org/rfcs/rfc2684.html
this leads to possible encapsulation problems
in short if  in the following debug command output
debug ppp negotiation
debug ppp authentication
if you never see a line that contains a capitol i I it means the router is sending messages but no one answers
Hope to help
Giuseppe
