Can I use config from 5505 on 5520?
Sep 20th, 2010
Customer is looking to test EZVPN in lab with 5505 head end and 3 or 4 5505 remotes. They will be doing less than 10 sessions. If they roll to production, they will use a pair of 5520s for the head end. While I believe all this should work fine, they asked if the work up the configuration in the lab on the 5505, can that be copied and then uploaded and used on the 5520?
Thank you.
Pat Johnson
Marcin Latosiewicz Mon, 09/20/2010 - 12:50
Pat ....
5505 uses different interface configuration (interface vlan) unlike 55-everythtingelse.
You cannot just copy and paste (apart from obfuscated keys) - everything else should be the same.
Marcin
