not passing traffic
bruce.lance
I have a problem with a
6509 connection the gig interface and uplink are in spanning-tree but the uplink does not forward traffic on the trunk even though it is allowed.
VLAN0222
  Spanning tree enabled protocol ieee
  Root ID    Priority    8414
             Address     0022.9189.a800
             Cost        4
             Port        513 (GigabitEthernet5/1)
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32990  (priority 32768 sys-id-ext 222)
             Address     0017.0f3c.b800
             Aging Time 1830
Interface        Role Sts Cost      Prio.Nbr Type
Gi5/1            Root FWD 4         128.513  P2p
Gi6/1            Altn BLK 4         128.641  P2p
Gi7/43           Desg FWD 19        128.811  Edge P2p
USSMCECEDSI001>sh int gi5/1 trunk
Port          Mode         Encapsulation  Status        Native vlan
Gi5/1         desirable    802.1q         trunking      1
Port          Vlans allowed on trunk
Gi5/1         1-4,8-10,12-15,18,20,26,30,48,52,57,60,62,71-72,80,85-86,199,204,222,227,229-230,234,236-237,239,242-243,247-248,250,268-275,300,305,329,338,345,350,360,363,365,372-376,383-387,389,391-392,530-533,536-537,558
Port          Vlans allowed and active in management domain
Port          Vlans in spanning tree forwarding state and not pruned
Gi5/1         1,3,9,13,15,57,60,71,85-86,199,227,229-230,237,239,242,247-248,250,268-275,300,305,329,345,365,372-373,375,383-384,386-387,391,531,533,537
5 Replies 5
Jon Marshall
Bruce
How are you determing that the link is not forwarding traffic ?
Jon
The mac address  001a.6d7c.8676 does not show up in the sh mac-address-table vlan 222 on the distribution and the IP is not in the arp entries for vlan 222.
Bruce
Okay, obvious question i'm afraid, where is that device ie. what switch is it connected to and is that switch on the other end of the trunk ? Whether it is or it is further down the line on another switch can you check all the trunk links back to the 6500 from the switch the device is connected into and make sure vlan 222 is allowed on all trunk links and that it is not blocked.
Could you also check the device is up and running and that it has no inbuilt firewall that would stop it responding.
Jon
The end device is a fw. the g7/43
interface is the e0/0 and the mac adress is 001a.6d7c.8676
the sh int g5/1 trunk command in the first posting shows the vlan allowed and in the domain but the vlan is not forwarding on the interface even though the spanning-tree commands say it is.
The two commands sh spannng-tree vlan 222 and the sh int gi5/1 trunk say two different things on the same switch.
Bruce
Oops, missed that, thanks for pointing it out. What is gi5/1 connected to ie. is it directly connected to the fw (by which i assume you mean firewall) or is there another switch in between (or multiple switches). Perhaps you could explain the topology.
If multiple switches can you check their status, specifically the vlan database ie. "sh vlan brief" and make sure vlan 222 is present.
Jon
