load balance based on OS
Answered Question
Sep 20th, 2010
Is it possible to load balance incoming requests based on client's operating system on ACE?
For example, we have different web pages specifically for Blackberry or iPhones.
Instead of having multiple URL's & VIP's, we'd like to have a single VIP, but load balance traffic to different serverfarms based on client's OS.
Correct Answer by litrenta about 6 years 8 months ago
You can loadbalance based on User-Agent header, first you need to quantify what Iphone and blackberry use for user-agent for instance from a regular browser you might see:
User-AgentT=Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; .NET CLR 2.0.50727)
from an iphone you will typically see:
User-Agent=Mozilla/5.0 (iPhone; U; CPU like Mac OS X; en)
AppleWebKit/420+ (KHTML, like Gecko) Version/3.0 Mobile/1C25 Safari/419.3
you can go to http://www.user-agents.org to find out what strings are used
That being the case you can make classes on the header to match for loadbalancing decisions:
class-map type http loadbalance match-any mobile
2 match http header User-Agent header-value .*iphone
4 match http header Uswer-Agent header-value .*blackberry
then in LB policy say we want to go to farmA for mobile and farmB for pc's
policy-map type loadbalance first-match L7POLICY
   class mobile
     serverfarm farmA
    class class-default
    serverfarm farmB
see:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/classlb.html#wp1021388
Overall Rating: 5 (1 ratings)
Correct Answer
litrenta Mon, 09/20/2010 - 12:14
  • Cisco Employee,
   class mobile
     serverfarm farmA
    class class-default
    serverfarm farmB
see:
