Help with DBwrite step
anthoney_murphy
I am attempting to create a new record and append new information stored in a variable to a table.  I am able to get the script  to do a static string but it will not use the value of the string variable I have setup.
For example:
user calls in and inputs their phone number.
script places the number in a variable called PhoneNumber
The DBwrite step attempts to upload and create a new record to table with the phonenumber field populated by the value in the variable PhoneNumber.
INSERT INTO tivr_test
(phonenumber)
VALUES
('PhoneNumber')
Ayn assistance would be welcome and appreciated.
khambetea
Did you try using $PhoneNumber?
khambetea
Its the oddest thing.  After I originally posted this I did use the
$PhoneNumber statement and it still did not work.  I then read somewhere that
IPCC and SQL handle string variables differently and that I would need
to convert the string to and integer in order to do this.  I did this but neglected to
change the SQL statement to use the int variable.
  I tested and was able to write the string to the
table.  It wasnt until I checked the SQL statement that I realized that i was writing a string to the database.  I am still investigating why it is now working.
