Hosts on same switch cannot see each other
Sep 20th, 2010
Greetings,
On our Cisco 2960-POE switch - connected hosts can see the switch VLAN IP, can get to and from both the corporate network (VPN) and Internet (split-tunnel) -  but cannot see each other.  We can ping one attached PC and an attached printer from the switch - but the PC can ping the printer.
Jon Marshall Mon, 09/20/2010 - 12:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What is the default-gateway on the connected hosts ?
Jon
iholdings Mon, 09/20/2010 - 12:46
Thanks for the prompt reply
The deafult-gateway on both devices is the IP address of the local firewall (192.168.3.1).
If we cross-connect the "old" switch (not sure of make/model) to the 2960 - and plug the printer into that switch - the hosts on the 2960 can see the printer.
This is the first time I've ever encountered this loss of intra-switch connectivity.
Thanks.
iholdings Tue, 09/21/2010 - 05:00
I guess that's possible - but I haven't seen any ports restricted or shutdown based on any policy violations.  They simply will not talk to each other across the switchports.
Am I better off setting the switch back to factory and reconfigure?  We are in a VoIP environment on that network - so I've been assigning roles IP Phone + Desktop for those ports where that's applicable.  Could that be the problem?
Thanks.
milan.kulik Tue, 09/21/2010 - 05:10
  • Red, 2250 points or more
as the first step, I'd simply identify the ports to which that PC and printer are connected.
Let's say those are ports  FastEthernet0/8 and FastEthernet0/9.
Then I'd simply:
conf t
interface FastEthernet0/8
no switchport protected
interface FastEthernet0/9
and test if you can Ping between those two devices connected.
HTH,
Milan
chabasimon Tue, 09/21/2010 - 05:12
A) You can configure data Vlan for Desktops cause i can only see the voice vlan.
B) You default gateway of your Hosts, shoud be your Vlan IP address, which for vlan1 is 192.168.3.253.
sure
