Flexible Netflow Support
Sep 20th, 2010
We're currently running netflow v5 and I'm trying to look into flexible netflow but couldn't find a document on which IOS or Supervisors supported flexible netflow.  Does anyone have a document that explains this? I tried following this link, but the first command in the sample config isn't recognized http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6555/ps6601/ps6965/prod_white_paper0900aecd804be1cc.html
Mani Ganesan Mon, 09/20/2010 - 20:52
Hi Joe,
Are you planning to move to netflow V 9 ?
Flexible netflow is not supported on the 6500 at this time.
Routers like 3800 does support flexible netflow but not on all the versions. You would need something latest in the 12.4T, like 12.4(15)T11 or
15.0 train to support this.
Here is some literature on flexible neflow including the config guide.
