CUPC 7.1 addin breaks outlook after kb2293428 patch is applied
Sep 20th, 2010
On our Windows XP sp3 with outlook 2003 once the patch is applied and the addin is enabled. You will get the "Outlook has encountered a problem an needs to close" when you launch outlook. Outlook will not launch untill you disable the addin.
Any ideas?
Matthew Kaufman Mon, 09/20/2010 - 18:52
  • Cisco Employee,
There is an open defect with CUPC.  Please open a TAC SR and when referencing your issue give them the bug ID CSCti94141.
--Matt
