IOS Ver 15.1.2 LAB
Sep 20th, 2010
I have a 2851 in my lab I currently use for voice testing.  The router is not under smartnet and oreviously I ran 12.4(9) to do all my testing.  The router was standard IP Base when it was purchased many years ago.  My quesiton is I want to upgrade to 15.1.2 in order to do a little testing. Is it even possible without a support contract to upgrade to 15?  I am sure the Lic will show up IP Base in 15 is there any way to get a voice lic?
Overall Rating: 4 (1 ratings)
Steven Holl Tue, 09/21/2010 - 07:10
  • Cisco Employee,
Feature licensing is only enforced in IOS for the 2900/3900 series routers.
You can put a 2800 on 15.1(2)T assuming you have memory for it.
You don;t need to purchase smartnet for the upgrade, but if you're running a featureset other than what you purchased, you should purchase the license upgrade for that appropriate featureset.  Talk to your account team regarding that.
b.eman Tue, 09/21/2010 - 07:12
Thank you, you are correct I have the new IOS loaded with no issues,
