EIGRP - Bundling and Load Balancing
Answered Question
Sep 20th, 2010
What is the difference between bundling links and load balancing links?
Links have to be equal cost right?
And EIGRP automatically load balances across them right?
So is bundling the same thing?
Correct Answer by Reza Sharifi about 6 years 10 months ago
I don't what building links is, but whom ever used properly meant link peering.
With EIGRP, they don't even have to be equal cost.  You can use the variance command and do unequal cost load balancing.  And yes, EIGRP by default load balances among equal cost links
Overall Rating: 5 (1 ratings)
Correct Answer
Reza Sharifi Mon, 09/20/2010 - 18:20
  • Cisco Designated VIP,
    2017 LAN
