Does anyone one know what is this ISDN error mean?
Answered Question
Sep 20th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
.Sep 21 10:18:37.209 AEST: ISDN Se0/0/0:15 Q931: TX -> ALERTING pd = 8  callref = 0x80D8
.Sep 21 10:18:46.489 AEST: ISDN Se0/0/0:15 Q931: TX -> CONNECT pd = 8  callref = 0x80D8
.Sep 21 10:18:46.509 AEST: ISDN Se0/0/0:15 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x00D8
.Sep 21 10:18:46.509 AEST: ISDN Se0/0/0:15 **ERROR**: call_progress: DEV_CONNECTED VOICE ERROR: Bearer capability not available(0x3A): b channel 4 call id 0xEDF
Correct Answer by Matthew Kaufman about 6 years 4 months ago
I believe that the voice quality issues may be unrelated, however I believe you're hitting defect CSCse55246.  This defect is resolved in 12.4(11)T2 as well as all the latest 12.4(15)T releases.
If this upgrade doesn't resolve your issue than you may wish to open a TAC SR and an engineer should be able to assist you further.
--Matt
Overall Rating: 5 (1 ratings)
Matthew Kaufman Mon, 09/20/2010 - 18:33
This could be related to a known defect in IOS.  What version are you running?  Can you provide a 'show ver'?
--Matt
victorchen Mon, 09/20/2010 - 18:36
40000158-S04-R01-AdshelMelbourne#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(11)T, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sat 18-Nov-06 17:16 by prod_rel_team
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
40000158-S04-R01-AdshelMelbourne uptime is 11 weeks, 6 days, 20 hours, 58 minutes
System returned to ROM by reload at 14:34:39 AEST Tue Jun 29 2010
System restarted at 14:35:57 AEST Tue Jun 29 2010
System image file is "flash:c2800nm-advipservicesk9-mz.124-11.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
Cisco 2811 (revision 53.51) with 247808K/14336K bytes of memory.
Processor board ID FHK1018F1B5
2 FastEthernet interfaces
11 Serial interfaces
1 ATM interface
1 terminal line
1 Channelized E1/PRI port
1 Virtual Private Network (VPN) Module
2 Voice FXO interfaces
2 Voice E & M interfaces
1 cisco service engine(s)
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
Matthew Kaufman Mon, 09/20/2010 - 18:39
Are you encountering any call issues, or just is it just the error you describe?
--Matt
victorchen Mon, 09/20/2010 - 18:42
only when people make internation call to NZ  has voice qulity issue.
Correct Answer
Matthew Kaufman Mon, 09/20/2010 - 18:45
--Matt
