Mac Based Support in 2960,3560G
Sep 20th, 2010
Dear Sir,
As discussed, please find below the existing switch models:
WS-C2950G-48-EI IOS: 12.1(22)EA4a
WS-C2960-24TC-L V02 IOS: 12.2(25)SEE2
WS-C2960-48TT-L V05 IOS: 12.2(44)SE6
We  intend to procure:
WS-C3560G-24TS-S - to be used as a core switch.
WS-C2960-48TT-L
Please confirm how we can enable MAC based security on the above mentioned switches. Do we need to procure any IOS upgrade etc. to enable MAC based security on all ports.
Jon Marshall Tue, 09/21/2010 - 03:28
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
What exactly do you mean by mac based security ie.
1) are you talking about using access-lists with mac-address
2) are you talking about using port security
3) are you talking about using 802.1x mac-address authentication
Jon
csco10904480 Mon, 09/27/2010 - 00:43
Hi Jon,
I am looking for following options :
2) are you talking about using 802.1x mac-address authentication
Regars
glen.grant Mon, 09/27/2010 - 05:06
  • Purple, 4500 points or more
   Your best is to just go to the cisco.com main page and do a search on each model .  Search on " configuring  2960, 3560 , etc...   It will popup the configuration instructions for each model.
