Guest Wireless Not working
Sep 20th, 2010
I have two controllers running code 6.0.182 and one guest controller with same version.
I can see the tunnel UP(Both control and data path) in both controller.
Guest users are authenticated by web authentication.Suddenly guest users become too slow to access internet.Web authentication is successfull.But its too slow to access internet.Did anyone face the same issue.Pls reply me at the earliest.
Danish Ahammed
Overall Rating: 4.3 (7 ratings)
Nicolas Darchis Thu, 10/07/2010 - 09:22
  • Cisco Employee,
if the web authentication was successful, then the clients are in "RUN" state and treated like any other clients. If there is a delay, it might be happening between your 2 WLCs. I would analyze with sniffer traces to see really what is slowing down the traffic
Nicolas
Davy Ad Sat, 10/09/2010 - 14:57
I need your advice , i have the same issue ,I can see GUEST connection status on IPad, but i can not brows/ access a web page .
Any Help pls?
Here is my Config;
no dot11 igmp snooping-helper
dot11 syslog
dot11 ssid OFFICE
   vlan 1
   authentication open eap eap_methods
   authentication network-eap eap_methods
   authentication key-management wpa
   accounting acct_methods
dot11 ssid GUEST
   vlan 40
   authentication open
   guest-mode
   wpa-psk ascii 7 XXXXXXXXXXXXXXXXXXX
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption mode ciphers tkip
encryption vlan 40 mode ciphers tkip
broadcast-key vlan 1 change 3600 membership-termination capability-change
broadcast-key change 3600
broadcast-key vlan 40 change 3600
ssid OFFICE
antenna gain 0
speed  basic-1.0 basic-2.0 basic-5.5 basic-11.0 6.0 9.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
rts threshold 2312
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.40
description GUEST
encapsulation dot1Q 40
no ip route-cache
bridge-group 40
bridge-group 40 subscriber-loop-control
bridge-group 40 block-unknown-source
no bridge-group 40 source-learning
no bridge-group 40 unicast-flooding
bridge-group 40 spanning-disabled
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
no keepalive
hold-queue 160 in
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.40
description GUEST
no ip route-cache
bridge-group 40
interface BVI1
description GUEST
ip address 10.10.X.X 255.255.255.0
no ip route-cache
ip default-gateway 10.10.X.X
no ip http server
ip http authentication aaa
ip http secure-server
danishahammed015 Sun, 10/10/2010 - 00:14
I cannot see the guest ssid inside dot11radio 0
Try to add it.
Danish
Davy Ad Mon, 10/11/2010 - 14:22
With enabled GUEST ssid , it is still the same issue.
Nicolas Darchis Sun, 10/10/2010 - 22:46
  • Cisco Employee,
Adewalexdavid => Well It's not the same issue as you seem to be under IOS while the original question was for controller environment :-)
The only thing wrong with your configuration is that you're not enabling the GUEST ssid on your AP at all. Under the "dot11radio0" interface you only have the command "ssid OFFICE" and no "ssid GUEST", so for sure your AP is not serving the GUEST ssid.
If your ipad shows "guest", maybe the ipad is configured to create the GUEST ssid as ad-hoc connection ?
can laptops connect to the guest ssid ? Is anyone receiving an ip address ?
danishahammed015 Sun, 10/10/2010 - 00:10
thanks for your reply
It was a issue with the policy setting on firewall.Now its working.
Danish Ahammad
Davy Ad Mon, 10/11/2010 - 05:18
Thanks,SSID was added , but i can not login with password.Regards,
Nicolas Darchis Mon, 10/11/2010 - 06:11
  • Cisco Employee,
Not sure what I can reply to this :-)
any message on AP console ?
what does a "show dot11 assoc all" says ?
Davy Ad Mon, 10/11/2010 - 13:50
But i am still having the same problem ,after enabling the GUEST SSID , My IPAD  cannot obtian IP address.
Could it be on RADIUS server ?
Nicolas Darchis Mon, 10/11/2010 - 22:57
  • Cisco Employee,
No radius involved since your guest SSID is using a wpa pre-shared key.
Can you try with something else than an ipad ?
do you see your client when doing a "show dot11 assoc" on the AP ?
Do you have a dhcp pool configured on the switch for vlan 40 ?
Nicolas.
Davy Ad Tue, 10/12/2010 - 23:34
Thanks Nicolas,
I have no Int Vlan 40 on the switch. I will configure that and get back to you ASAP.
Would i need to change the IP on BVI1 and also what about Default Gateway on Access Point, and on Switch?
My config on Switch
interface VLAN1
ip address 10.10.10.22 255.255.255.0
no ip directed-broadcast
no ip route-cache
ip default-gateway 10.10.10.1
My config on Access Point
interface BVI1
description GUEST
ip address 10.10.10.9 255.255.255.0
no ip route-cache
Dak
Nicolas Darchis Tue, 10/12/2010 - 23:39
  • Cisco Employee,
You need an interface vlan40 on a switch that will act as gateway for the clients.
The BVI1 is just to telnet the AP and manage it, so it's fine as it is. The only "strange" part is that your management of the AP is in the guest vlan. So once you have everything working, you might think about having the bridge group 1 and BVI1 on AP that are not for guest access. But no showstopper there.
Davy Ad Wed, 10/13/2010 - 00:10
Thanks Nicolas,
so I need to configure this on SWITCH
interface Vlan40
description guest
ip address 10.10.10.X 255.255.255.0
ip access-group GUEST_ACC in
ip helper-address 10.X.X.X
no ip redirects
Will i need to configure default gateway for Vlan 40, with the above config is on my switch and without changing anything on AP ,everything should be fine?
Dak
Nicolas Darchis Wed, 10/13/2010 - 00:14
  • Cisco Employee,
Wow, lots of confusion.
With the current config you showed, you are putting the vlan 40 interface in the same subnet as your vlan 1. This is not good.
There is only 1 default gateway per device. So AP has its default gateway in vlan 1, fine. And your switch already had a defautl gateway, so fine as well.
Simply what is needed is : AP configured with 2 vlans (1 and 40), simply bridging them. One switch somewhere having a vlan interface for both vlan 1 and 40 and a dhcp pool for each subnet.
Nicolas
Davy Ad Wed, 10/13/2010 - 01:57
Hi Nicolas,
It was typo error , Vlan 40 and Vlan 1 are not on the same subnet.
I just want to know , if i need to create another default Gateway for Vlan 40 on SWITCH.
I know that there is only one default gateway per  AP, which i did. and i have the two Vlans configured already on AP.
My Question is what you mean by Bridging them ; "simply bridging them. One switch somewhere having a vlan interface for both vlan 1 and 40 and a dhcp pool for each subnet."
is it on Switch or AP. And How?
Dak
Tiago Antunes Wed, 10/13/2010 - 01:10
  • Cisco Employee,
Here you can follow a detailed config example for IOS AP with 2 VLANs, including the configuration on the L3 switch for the VLAN interfaces and dhcp pools:
http://www.cisco.com/en/US/partner/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml.
Hope this helps.
Tiago
PS. Next time please open a discussion for your setup as it has nothing to do with the original post..The original post was for LWAPP deployment.
Yours is for Autonomous AP.
Tiago Antunes Wed, 10/13/2010 - 02:33
  • Cisco Employee,
Can you please try here:
https://supportforums.cisco.com/servlet/JiveServlet/downloadBody/13436-102-1-30898/vlan_ap_config.pdf.
or
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} http://www.cisco.com/en/US/customer/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml.
Davy Ad Wed, 10/13/2010 - 07:10
Hello ,
 I tried to configures int vlan 40 and enable it with "no shutdwon",
when i check on the interface , it is down dwon
 VLAN40                      10.0.0.18       YES NVRAM  administratively down down    .
Any Help
DAk
Hello ,
Any Help
DAk
Tiago Antunes Wed, 10/13/2010 - 09:30
  • Cisco Employee,
As any L3 VLAN, the VLAN needs to be configured on the switch and will only come up if you have it on an interface.
You need to create the vlan, create the vlan interface and add it to the allowed vlan list on the trunk where the AP is connected.
Have you gone through the document i suggested to you?
Did it helped?
Tiago
Davy Ad Wed, 10/13/2010 - 23:03
Hello Tiago,
I appriciate all your effort, i want you to know what i did already and if i am wrong in my configuration let me know  .
On SWITCH I created access Vlan for GUEST and Phone
Int fa0/12
Switchport mode  access
switchport  access vlan 40 >>>>> GUEST VLAN
switchport voice vlan 10 >>>>>>>Phone VLAN
spanning-tree portfast
still Int vlan 40 is still the same ( down down)
Incase  you want more information let me now. the switch is  Cisco 3548 XL
Tiago Antunes Wed, 10/13/2010 - 23:53
  • Cisco Employee,
Is that the config of the port where the AP is connected???
Why would you configure a switchport voice vlan there??
Where have you seen to configure an access port where you have the AP connected  on the document i sent you?
Can you just follow the document?
The config on the port where the AP is connected should be something like:
Switch#configure terminal
Switch#interface fastethernet 0/10
!−−− Enter the interface mode for Fast Ethernet 0/10
Switch#switchport mode trunk
!−−− Configure the switch port mode to trunk mode.
Switch#switchport trunk encapsulation dot1q
!−−− Configure the encapsulation on the switch port to dot1q.
Switch#switchport trunk native vlan x
!−−− Configure the native VLAN as VLAN x.
Switch#switchport trunk allowed vlan add 2,20,30
!−−− Configure the list of VLANs that are allowed on the trunk port.
Switch#switchport nonegotiate
Tiago
Davy Ad Thu, 10/14/2010 - 01:47
Tiago,
No that is not the port AP is going to be pluged in, the configuration was already there before think of AP .I just want to inform you that Guest network or Vlan is already defines in some port. I know that AP port need to be Trunk .which i did already and at the port i allowed all vlans.
dak
Tiago Antunes Thu, 10/14/2010 - 02:00
  • Cisco Employee,
Ok, so are those interfaces up?
Can you share with us the output of "sh int status" and "sh vlan"?
Tiago
Davy Ad Thu, 10/14/2010 - 03:53
I will get back to you latter , i am at different site.
Dak
Davy Ad Thu, 10/14/2010 - 10:23
Hello Tiago,
Here is all the info you requested for .But i have not plug AP into any port
are these
1    default                          active    Fa0/1, Fa0/3, Fa0/4, Fa0/6,
                                                Fa0/8, Fa0/10, Fa0/12, Fa0/13,
                                                Fa0/14, Fa0/17, Fa0/21, Fa0/22,
                                                Fa0/23
2    DATA_rfarafarrfa                 active
20   VOICE_voippppp                   active    Fa0/5, Fa0/15, Fa0/16, Fa0/18,
                                                Fa0/19, Fa0/24
21   VOICE_Prorama12                  active
50   Weada                            active    Fa0/7
51   VB_PErafaraf_1                   active    Fa0/9
40   GUEST                            active    Fa0/20
1002 fddi-default                     active
1003 token-ring-default               active
1004 fddinet-default                  active
1005 trnet-default                    active
Fa0/8                      notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/9   XXXXXXXXXXXX1      connected    51         Full     100 100BaseTX/FX
Fa0/10                     notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/11  PC + PHONE         connected    trunk    A-Full   A-100 100BaseTX/FX
Fa0/12                     notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/13  CCCCCCCCCCCC       notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/14  PPPPPPPPPPPPP      notconnect   1          Auto    Auto 100BaseTX/FX
Fa0/15  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/16  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/17  cravafabsbs nic 2  connected    1          Full   A-100 100BaseTX/FX
Fa0/18  VOIP               connected    20         Full     100 100BaseTX/FX
Fa0/19  top PC             notconnect   20         Auto    Auto 100BaseTX/FX
Fa0/20  VLAN 40 GUEST Inte notconnect   40        Auto    Auto 100BaseTX/FX
Port    Name               Status       Vlan     Duplex Speed   Type
VLAN1                      10.10.1.1     YES NVRAM  up                    up
VLAN40                     10.20.40.1      YES manual administratively down down
FastEthernet0/1            unassigned      YES unset  up                    up
FastEthernet0/2            unassigned      YES unset  up                    up
FastEthernet0/3            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  up                    up
I hope these infos are what you want?
Tiago Antunes Thu, 10/14/2010 - 23:45
  • Cisco Employee,
So looking at your post it is clear why the VLAN is down...
The VLAN will only come up if the VLAN is active in any port of the switch.
And looking at the output, you only have VLAN 40 assigned to one interface, and that interface is not connected "Fa0/20  VLAN 40 GUEST Inte notconnect   40 " so untill you connect a device to this interface, it will always remain DOWN.
HTH,
Tiago
If this answers your question please mark the question as "answered" and rate it, so other users can easily find it.
Davy Ad Fri, 10/15/2010 - 01:26
i will get back to you . I am  on other site.
Dak
Davy Ad Mon, 10/18/2010 - 07:32
Hi Tiago,
I just want to inform you that the AP can not connect to GUEST .  Here are the information for trouble shooting.
1.
Oct 18 14:17:03.120: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
1aa Associated KEY_MGMT[WPA PSK]
Oct 18 14:17:30.080: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 402b.a1d2.51aa Reason: Sending station has left the BSS
Oct 18 14:17:30.141: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:04.439: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:04.606: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:05.650: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:10.229: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:18:42.313: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:18:46.923: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  402b.a1d2.5
Oct 18 14:19:04.485: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
99f Associated KEY_MGMT[WPA PSK]
Oct 18 14:19:18.970: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:19:34.492: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Station 0024.9f52.c99f Reason: Sending station has left the BSS
Oct 18 14:20:20.041: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:20:50.049: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:21:01.792: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:21:31.799: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:21:45.636: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
Oct 18 14:22:15.647: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating
Oct 18 14:22:34.543: %DOT11-6-ASSOC: Interface Dot11Radio0, Station  0024.9f52.c
2. show ip int brief :
ocol
VLAN1                      10.21.48.44     YES NVRAM  up                    up >>>>>>>>>>> NATIVE VLAN
VLAN9                     unassigned      YES unset  administratively down down
VLAN40                     10.21.41.2      YES manual administratively down down>>>> GUEST VLAN
FastEthernet0/1            unassigned      YES unset  down                  down
FastEthernet0/2            unassigned      YES unset  down                  down
FastEthernet0/4            unassigned      YES unset  down                  down
3. on AP show ip int brief
ocol
BVI1                       10.10.48.X      YES NVRAM  up                    up
Dot11Radio0                unassigned      YES NVRAM  up                    up
Dot11Radio0.1              unassigned      YES unset  up                    up
Dot11Radio0.30             unassigned      YES unset  up                    up
Dot11Radio0.40             unassigned      YES unset  up                    up
GigabitEthernet0           unassigned      YES NVRAM  up                    up
GigabitEthernet0.1         unassigned      YES unset  up                    up
GigabitEthernet0.40        unassigned      YES unset  up                    up
4. Trunk Port configure and AP install in Switch port as well
Building configuration..
Current configuration:
interface FastEthernet0/25
description TRUNK-to- GUEST Wireless
speed 100
switchport trunk allowed vlan 1,40,1002-1005
spanning-tree rootguard
5. Admin User can connect and browse internet ,but the Guest user can not connect.
This is where i need solution>
I read the pdf you sent, and my Configuration is nearly the same. except hat i used TACAC & Radius server.
Dak
Tiago Antunes Mon, 10/18/2010 - 12:06
  • Cisco Employee,
We still see the vlan 40 down/down on the switch...
And what do you mean by "used TACAC & Radius server"?
From the logs the ssid is configured for PSK...is this what you intend?
What is exactly the secuity method you are aiming for?
Can you please share with us the sh run of the switch and of the AP?
Please save them on 2 files and upload the files. Do not paste it here.
Cheers,
Tiago
Tiago Antunes Mon, 10/18/2010 - 23:28
  • Cisco Employee,
Well, looking at the switch configuration we can clearly see why the vlan 40 is still down down...
This is what you have:
interface VLAN40
description GUEST
ip address 10.10.40.2 255.255.255.0
ip access-group guest-list in
ip helper-address 10.10.10.13
ip helper-address 10.10.10.12
no ip redirects
no ip route-cache
shutdown
Don't you see anything that shouldn't be there?
(Hint: command "shutdown")
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as  "answered" and/or rate it, so other users can easily find it.
Davy Ad Tue, 10/19/2010 - 03:52
Thanks ,
 But i told you many times in all my mail that i did "NO SHUT DOWN" already , and the port still down down. If it is just no shut down.I will not be waisting your time to tell me what is wrong.
I enable the port interface
I plug in the AP
I enable int vlan 40  ( with No shut )
But, it is still down down. All these i did before asking for Help.
Dak
Davy Ad Mon, 10/25/2010 - 21:34
Hello ,
I will like to thank you all for your support , specially on PDF document sent by Tiago.
After lots of trouble shooting,  AP was able to work normally, connected to both GUEST and Admin User (except  one IPAD on GUEST Network)
The Problem was no passive interface for GUEST Network on OSPF routing protocol.
Dak
Tiago Antunes Mon, 10/25/2010 - 23:30
  • Cisco Employee,
Nice to hear that.
Glad that is working and thanks for sharing the root cause on the routing side.
Cheers,
Tiago
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
