Does shape class-default help to limit LINK Bandwidth.
Sep 21st, 2010
We have procured new link BW of 40Mb but our router have the capcity to support 30Mb only.We are planning to configure as below to do shaping for 30Mb only.Does shape wan QOS support to restrict the link BW to 30Mb, it is against to actual 40Mb...
interface GigabitEthernet0/1
bandwidth 30720
service-policy output shape-wan
policy-map shape-wan
class class-default
  shape average 30720000 960000
Pleas help.
Giuseppe Larosa Tue, 09/21/2010 - 04:00
  • Hall of Fame,
    Founding Member
Hello Binu,
IF it is a  software based router that supports modular QoS your configuration will be accepted and it will do what you want to achieve.
I wonder however, if it is appropriate to use it as if the router has performance limitations it is auto limited to a value less then 40 Mbps it would be wise to shape on the other side and probably is what you want to do
Hope to help
Giuseppe
Binu Steephen Tue, 09/21/2010 - 09:30
Thanks!
I will apply shape-wan at both side.
Router is cisco 7206 12.3-12e.bin IOS router..Does it meet this requirement? Please advise
Giuseppe Larosa Tue, 09/21/2010 - 14:02
  • Hall of Fame,
    Founding Member
Hello Binu,
you are fine with software based routers that include the C7200.
Shaping on the weaker side may be considered not a necessity as router performance are lower then WAN bandwidth.
Hope to help
Giuseppe
