3502 AP - Infection Control
Sep 21st, 2010
I'm from a hospital, we're looking at usiing the new 3502 AP's on some new builds.
Becouse of Infection Control, I'm looking for a sheaf or seal to cover the gap between the surface the AP is mounted to and the AP it self to stop dust getting in, but also allow ventalation.
Has anyone come accros such a device?
Cheers
Craig
Serge Yasmine Wed, 10/13/2010 - 13:51
  • Cisco Employee,
Hi Craig,
Very interesting question, i think the best is to reach out to your Cisco Sales Team or Cisco SE. They will check this question for you.
Serge
Leo Laohoo Wed, 10/13/2010 - 14:16
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
We are using this for 1140:
http://www.terra-wave.com/shop/polycarbonate-enclosures-10x10x2-polycarbonate-enclosures-c-229_242_244_280.html
Should work in a hospital environment.  Both have ventilation holes which also allows visual inspection of the LED lights.
The product specs is does not include the 3500i or 1040 but if you look at the product specs of the 3500i, 1040 and the 1130/1140, you'll notice that the dimensions are pretty much similar and they'll most likely fit.  If you are still in doubt, order one and check it out before ordering the entire lot (that's what we did).
Please don't forget to rate our useful posts.  Thanks.
qfpaldhous Tue, 12/28/2010 - 03:05
I think what you are looking for is an ingress protection rating, confusingly enough given as an enclosure IP rating. This is mainly given for ventilation and access. IP0.0 means full access full ventilation, IP3.0 means restricted access full ventilation, IP6.5 can be placed outside and will stop rain and airflow getting in, but relies on heat dissipation to be carried out within the enclosure. Please look at any electrical enclosure manufactuer for further details. I would not be tempted to just seal up a wireless box, as restricting airflow can cause boxes to over heat.
Vinay Sharma Sun, 05/29/2011 - 07:03
  • Gold, 750 points or more
Please mark the Question as Answered if the provided information is correct and issue is fixed.
thanks,
Vinay
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
